Delta Air trunk system
gldavis
KE7MQF
Bountiful, UT
After monitoring the Delta system I suggest the following changes to the database.
I submit them for your approval/comments.
Remove "Delta" from the display name.
TG Display Name Description
4128 De-Icing Pad Ops De-Icing Pad Operations
4144 B Gates B Gates Coordination
4176 C&D Gates Alt Alternate channel for C&D gates
4272 De-Icing Ch-3 Alternate channel for De-icing Pads
4304 De-Icing maint De-icing Equipment Maint
4512 Avionics Maint Avionics Maintenance
4800 De-Icing Unk De-icing use
37136 Gnd Cntl Tower Ground Control Tower Tie-in
gldavis
KE7MQF
Bountiful, UT
It is the Delta Airlines system. I'm just wondering why that needs to be stated with every single talk group? Removing "Delta" would leave room for a more descriptive user name.
enosjones
Price, Utah
Yeah it does seem redundant, I'm sure it could be abbreviated or removed completely
Sent from my iPod touch using Tapatalk
bbrasmussen
Woods Cross, UT
Deicing shouldn't be spelled with a hyphen. Saves another character.
I'm curious what you heard on TG37136 Gnd Cntl Tower Ground Control Tower Tie-in ? Is that radio traffic on the Delta System with the FAA Tower and the Ground Controller position, or is that Delta Tower coordination with ground agents? If it's coordination with the FAA Tower about aircraft movements, it would make more sense to label that channel as having to do with DL Ramp/ATC Coordination. (In this case you might want to leave DL in the description since that is what they are referred to on the radio.)
gldavis
KE7MQF
Bountiful, UT
It was a while ago, so I try to remember. I did not catch who called, but it was on the Delta system, Someone called ground tower, and they responded. Comms about the movement of aircraft. I heard it the one time, and not since. It was late last year (2016) when I heard it. Does this help?
