Detroit Police Frequencies - Help
Radiowes123
I finally purchased a 800 Mhz scanner with Trunking and am trying to program Detroit. I understand that they are on this new system.
I became confused with all of the different frequences and talkgroups that Detroit has. I am trying to program police dispatch to car, car to dispactch as well as car to car for all of the districts except Central.
If anyone has the general frequencies/talk groups that I should use and can send them to me I woudl greatly appreicate it.
thanks!!
mikey60
Oakland County Michigan
thanks!!
Which "800Mhz scanner with Trunking" did you buy? If you can provide that information, I wouldn't be surprised if someone can provide a file for you (assuming the radio you have supports digital trunking, which the Detroit System Uses).
Mike
ROCKnTIME
You need a digital scanner to receive Detroit. Your scanner is an analog scanner and unable decode digital signal.
