Diamond Discone Upgrade
abqscan
DataBase Administrator
Moderator
AOA
What were you using for your prior antenna?
jimmnn
Colorado
Assuming you are just referring to improved DTRS reception? Interesting because the Diamond is designed very wide band; Bands: 25-1300 MHz.
If your seeking 800MHz only I would recommend a yagi designed for that band.
Jim<
04Z1V6
Castle Rock, Co.
Eric I was using ether a 800Mhz radio shack duck or there little sputnik antenna.
Jim I listen to both conventional and 800 a little of the local ham repeaters and air traffic control, some of the areas south and east use older fire frequencies. I have a yagi I use sometimes to point at Elpaso County and it seems good for directional listening. I would like to have your recommendation for that yagi but it must be able to be used in my attic. I can't put up a tower or large exterior antenna.
abqscan
Moderator
AOA
I'm glad your seeing improved reception with the outdoor antenna! =)
