Dickinson county
timkilbride
Linn Co Iowa
What you are likely looking for are the talk group numbers. Do you currently have a receiver capable of monitoring ISICS? If you do have a receiver, put said receiver into "search" mode, if capable, and that will revile talk groups not currently programmed into your receiver when someone is using those talk groups.
Tim
Herkyfan24
Hartley, IA
Tim
I have the SDS100 I was just hoping somebody would have had the info without needing to search for it.
radioboy75
Rock Rapids, Iowa
They are not actual frequencies, so don't think of it as an old-fashioned frequency search that takes forever. It's just putting the system into search mode. Everything will come in as immediately as it always does. It's just letting talkgroups come in that would be ignored in "scan only" mode. Searching on a trunked system is just a toggle -- not a new mode that you have to put the scanner in for days, waiting for the right frequency to pop up. In fact, mine are ALWAYS on search mode in case something new comes in on that system. Please let us know what you find out. We could use more information from your area! Check this video. It tells you what you need to know.
radioboy75
Rock Rapids, Iowa
That was the 436, but it should be the same on the SDS100. Here's a video on that particular model, but you'll see it's the same.
Herkyfan24
Hartley, IA
I did that and as of right now I was able to find one of the 2 channels on TGID but obviously pain staking it is I will be waiting more still plenty to discover
