Disaster Preparedness - GMRS
rf_patriot200
Freeport, Illinois
Not sure if you are joking, but NotaRubi is short for NotaRubicon. It is a GMRS repeater in the Riverside area of California.
Right, but that wouxun radio in the previous screenshot was showing notarubi in the display, and I commented that it's a Color choice on the 935G/ 935H . Not a Rubicon is also a well known Gmrs YouTube user. (y)
Coffeemug
Warminster BUCKS Co. PA
Noob here and first time posting so please go easy on me. Very limited knowledge and experience with radios, however I own a cheap Midland GXT GMRS radio to communicate with family in the area should there be some type of emergency.
We do regular check ins every few months to make sure everything is working order. We are only 1.8 miles away from each other and my question is would upgrading the radio to something that a has a bit more wattage improve the clarity? I get conflicting information but appears this radio model is 2.8 watts on high power.
We are in typical suburbia with trees and one story business buildings in the line of sight. Just looking to improve the quality of the transmission.
Thanks in advance for your time and help!
I assume that those GTX radios all have fixed permanent antennas. Others are right, if you're going to invest in radios. You should invest in radios with removeable antennas, such as the BTECH GMRS PRO, even though this particular radio it's supposed to have a removeable antenna, because Digital Data Rule.
sempai
Iowa City, IA
an early review i read said they had glue around the antenna on theirs, but i've got four in this house and not a one gave any resistance at all. i also have this radio's cousin the Vero VR-N76 but that's sold for amateur use. if you mash the "battery status" indicator in the mobile app it will set it to "factory test mode".
i upgraded the powerbanks in my go-bag valets recently. ugreen has a very slim 25k mAh batter with three PD outputs and it'll fill my iPadPro, iPhonePM 15 in record time.
**just a reminder that many devices that claim usb charging because they slap a type-C port on it apparently save a dime by not putting in whatever is in a typeA-to-typeC cable that allows power to pass over it because a typeC-to-typeC off an actual USB charger will not charge the radio** i have a lot of gear (including radios) where you have to use an A-to-C cord from a wall wart, to charge off a powerbank, or computer's type-A port that way.
no doubt an EE or experienced ham will explain what i misunderstood about this but the end result is the same: don't count on type-C wall warts and break-out boxes and c-to-c cables to do a g-ddamned thing for you unless you charge off a computer or your Uniden in-dash unit with an output there.
amazon has many good options for 12'+ typeA-to-typeC cables. i get them braided with binders and color match the valets so at a glance i can see if it's ready or not.
cavmedic
Pottstown Pa
You misunderstood what we were talking about. We were discussing muting background radio traffic on the same frequency, NOT trying to hide the transmitted signal . In other words, using CTCSS what it's intended for .
He didn't misunderstand, when they find your tone , it will be no longer muted.
cactus360
First off I would start by saying your chances of getting busted by the FCC when operating as proposed are slim to none. If you do draw the attention of several GMRS users your chances of getting turned in go up, squeaky wheel gets the grease theory. But still pretty slim.
I think there is a big difference between knowing the rules, licensing requirements and regulations, and saying when an emergency arises I plan on doing it anyway. Despite knowing better and having the chance to adequately prepare for such an emergency. And,....
grabbing and using a radio when you find yourself in a one off unexpected emergency situation and are forced to do so.
In other words it comes down to intent. Like I said, you probably won't get busted. But, proceed with caution.
