BCD436HP/BCD536HP: Discovery Mode Error
pb_lonny
VK7AAL
Tasmania
Has anybody else come across this:
Running in discovery mode against a 800MHz EDACS trunking system, when reviewing the results you have hits logged for talkgroup 00-000, when you try and review these and play the audio the scanner shows a SD card error and won't do anything until a battery is removed.
pb_lonny
VK7AAL
Tasmania
I have repeated this test against two other EDACS sites with the same results, any ideas?
pb_lonny
VK7AAL
Tasmania
It appears to be when it finds an icall and tries to record it, a bug worth reporting to Uniden?
dave3825
Suffolk County NY
What firmware version is on your scanner? Not sure if its the exact same thing or not but there was an update a while back that claimed to have fixed (SD Card Read Error" during Discovery Review)
1.08.06 (September 3, 2015 Release)
FIxed "SD Card Read Error" during Discovery Review (thank you TigerMoth for finding)
Activated replay duration on menu navigation
Added menu navigation support to serial protocol
BCD436HPFirmwareUpdate < UnidenMan4 < TWiki
pb_lonny
VK7AAL
Tasmania
Thanks, I think that is it.
I have the Australian version (UBCD436-PT) but we have different firmware versions so they might not have included that for us yet, if at all. I am running the latest version as I checked via the software last night.
kc9svj
GA
I haven't had this problem. Have you had much like finding new sytems with discovery? The little bit I've tried it didn't seem to do much for me.
