RFI-EMI-GUY
- Joined
- Dec 22, 2013
- Messages
- 7,526
It's indeed a CCR issue. Companies buying the cheapest POS radio and circumventing the usual safeguards. Did they bring them to an established radio shop to have an FCC licensed technician program them? No. Did they download CHIRP from the internet and hack away at it. Yup.The problem with that is that it isn't a CCR issue. It's a licensee transmitting on unauthorized frequencies...nothing more, nothing less. The same could be done with a Moto or Kenwood or anything else.
In fact, no CCR I have ever seen has a default offset. I'm sure some exist, but none of the ones I have used do. RX and TX frequencies have to be programmed separately. Chirp has auto offset, but the actual radios themselves usually don't, as they were never originally intended to be ham radios. And all of the default frequencies I have seen are set up for simplex. So it is potentially a CHIRP issue. But then again, an offset can also be programmed using the Motorola CPS.
Sent from my SM-T350 using Tapatalk
