What system?I'm trying to get a conventional P25 ID.
Can I stop this and just have it only display the UID? If not, can I control what the "ID:1" displays with maybe POLICE or FIRE instead?
When the subscriber unkeys, the ID disappears. Is there a setting that will leave the display for x seconds after a transmission?
The 396XT should work the same way.
Technically, there is a TGID. P25 conventional defaults to TGID 1 unless someone changes that, which they almost never do. That is why you are seeing ID:1 alternating with the UID of the transmitting radio.The scanner is in search mode since there are no talk groups IDs.
As expected per the explanation above.The display is switching back and forth between "ID:1" and "UID: ixxxxxxx" with x's being the unit ID.
Nope.Can I stop this and just have it only display the UID?
Maybe. It depends on how you've setup OFT. If you put both 460.3625 and 453.775 into the same OFT system, then no you cannot label them individually because both frequencies use the same default TGID of 1, and therefore there is no way to distinguish them. If you created two OFT systems, one for each frequency, then yes you can alias TGID 1 differently within each system, as they won't be aware of each other in the scanner's programming.If not, can I control what the "ID:1" displays with maybe POLICE or FIRE instead?
Nope.When the subscriber unkeys, the ID disappears. Is there a setting that will leave the display for x seconds after a transmission?
