Display Settings
ofd8001
Louisville, KY
Will the display settings used for the SDS100 import/copy to the SDS200 satisfactorily or is there additional "things" that are needed/desirable?
nessnet
What month is it?
I would make sure to change the target model (tools / target model) to the correct one.
But, the answer to your question is yes, display settings are the same
trentbob
Silent Key W3BUX
Bucks County, PA
When I transferred my display from my 100 to the 200 I had to add additional characters to extend the line going across the top. As you can see the 200 is stretched out and holds more characters as has been said. Look at the shape of the arrow.Resized_PSX_20200722_061321.jpeg
trentbob
Silent Key W3BUX
Bucks County, PA
Also I find it interesting when you transfer from the 100 to 200 the Alpha tag was centered correctly in the 100 but off center to the left, also because of the stretching, on the 200. Very minor issue.PSX_20200722_071909.jpeg
TailGator911
Silent Key/KF4ANC
Fairborn, OH
I have that issue with the splash info on the startup screen, for some reason it is lined up on the left. I go in and center it in Sentinel, but to no avail. It will not center for some reason. Not a major gripe unless you are OCD Positive like me lol
