Sentinel: Sentinel 3.01.01
rhodester
Saratoga County, NY
Sentinel 3.01.01.Target model sds100.Edit display detailed trunk and detailed conventional.Should have separate usb voltage 1 & 2.But only has usb voltage no number.Chose that for both then write to scanner.Both came up usb voltage 2.Had to do it on the scanner display settings to get usb 1 voltage to show up..
tvengr
Well Known Member
Baltimore County, MD
That sounds like a question for Jason, the Uniden rep. I agree that there is a problem with Sentinel. With Target Model set to SDS100, only one USB Vbus Voltage option is available. There should be a separate setting for each jack.
