Is there a way to see the CC in a DMR system or is there a way in the Freescan Software to add it?
While FreeSCAN 2.19b1 theoretically "supports" DMR, that support is limited. FreeSCAN does not give you an option to enter a color code for conventional or trunked systems. It's not available as an "audio search" option either (for color code). Web imports on DMR trunked systems are also incorrect, importing them as Motorola Uhf. For conventional DMR channels, the color code is not imported, and as noted above, there is no field to enter it.
Your only work-around is to set as much of the system as you can in FreeSCAN, then after loading your file to the scanner, go in manually via the scanner keypad to fill in the color codes. Note that on web imports of trunked systems, when the software pulls a trunked system as
"Motorola Uhf", you can change the system type to DMR in FreeSCAN (it will warn you about changing system type (just ignore the warning) and then save the file. Once uploaded to the scanner, then go back in & set your color code.
Your better solution is to use ProScan, which fully supports DMR, and covers a large number of scanners.
