DMR Help
renegade3552
I bought one of these beauties. It's a little tedious than I am used to. But I am sure I can figure it out with a little help.
Anyways, I managed to get a DMR Motorola Capacity Plus Single Site (TRBO) to work temporarily. Then after a few transmissions it seems to stop picking it up. Did I miss or not set up something correctly?
  • Like
Reactions: btt
btt
Jew lover
Banned
Wa State
Sorry for the delay in response to your question. While some effort has been made toward getting Cap+ working, it is still not working right. In the latest releases, Con+ and conventional should be working well.
renegade3552
Thanks, Bud. On my research I did read it's hit and miss. I am using the stable release 02-10_1045. Would you recommend I use any of the other releases then? I also noticed the software will crash if I leave it running on Windows 11. If I manually close and reopen the software it'll run fine again. The device itself is running fantastic on P25.
btt
Jew lover
Banned
Wa State
There is a new release available for those that do not want to update to the experimental firmware/software yet. Version 2022-06-01_0432. Please see the P25RX-II firmware updates thread for more info.
