DMR Lee or Collier County?
107pilot
FL
Have upgraded to DMR everything turned in Sentinel. Not hearing anything.. What do you listen to with DMR? I did a fresh install of only DMR freqs in Collier County, Hospitals. Am i doing something wrong? Can any of you advise what DMR you listen to in Lee or Collier County that you are receiving?
Thank you!
Whiskey3JMC
Another Pesky Scanist
Simulcastylvania, TE
If said DMR is listed in the database you'll need to enable the applicable service types as shown in the "Tag" column in the RRDB. If you're listening to hospitals then the "Hospitals" service type will need to be turned on otherwise the scanner will omit traffic from those channels or talkgroups tagged as such
107pilot
FL
Thank you for your help. I have the service type checked . I am not sure what you refer to as the “ Tag" Column in Radio Reference DB?
107pilot
FL
I do have those services selected for Business and DMR. I checked those in edit profile. I must be missing something, I apologize for bothering you,
Nasby
Ohio
I’ve never heard any good DMR in Collier other than landscapers, golf courses and hotels/resorts. Most of Collier hospitals and other coms occur on their phase 2 p25 system.
107pilot
FL
The only Phase 2 P25 system that I hear on Collier Hospitals is, Ambulance to the Hospitals, or vice versa. I have never heard any hospital operations like engineering, or security on P25. RR has them listed as DMR.
Nasby
Ohio
Look under the Collier P25 system for NCH health system. They are there and they are active.
107pilot
FL
That is exactly where I loaded the DMR system for NCH. All NCH hospitals show DMR and a couple of conventional frequencies which are active, doesn't show which hospital is on the conventional frequency. however the DMR is quiet, they are not encrypted. Lots of DMR activity at the resort hotels.
Nasby
Ohio
The DMR listings are not the same as the Collier County Phase 2, P25 system.
You’ll hear the hospital radio traffic on the Collier P25 system, not the DMR systems you uploaded.
107pilot
FL
I understand that, Collier P25 phase 2 system is fine for hearing or listening to Hospital to Ambulance, or vice versa, they are not on the DMR system. The DMR that is listed is for the hospitals for security and engineering only, and I am being told you have to set up a DMR favorites list separate from other systems to monitor DMR, which is what I did.
