DMR on G5
Uni1
Unication Representative
DFW Texas
All G5 support Conventional DMR tier 1 and 2 only. No trunking.
No hardware change is needed. DMR is enabled by the G5 model number "67". If your model is a 64 or 66, DMR will not work no matter what firmware version you have. The current firmware V1.1 supports DMR if your G5 is a "67".
We have a utility to change the model number of any G5 to a "67". Dealers will be getting the utility and instructions some time next week. After that it will be on our web site for all current G5 owners.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
So is my method of programming a "67" profile into my "64" unit not a supported way of accomplishing this? My unit now reports it's a "67".
Uni1
DFW Texas
Your G5 is still a model 64. Go to the programming screen.
KevinC
32D2T/957.282
Super Moderator
I'm not going to argue with you, but mine shows to be a 67...
ETA...I'm a goober I guess. I looked at my box and mine has always been a 67. The profile I used to originally program it was from a 64 and I never looked at the field you mentioned. I'll go back in my little hole now.
DanRollman
Atlanta, GA
Thanks for the tip re: the box. Apparently I am in the same boat as you - my current G5 (relatively new) turns out to be a 67 according to the box, even though I currently have programmed in it a file from a 64 I had a few years ago. Two issues for me, if anyone has any tips:
1. Any way to convert an existing 64 model PPS file to a 67 (where the radio is already a 67) so as to enable the ability to add DMR channels without loosing the P25 channels that are already in the file? I tried "re-reading" my programming from the radio back in to PPS, but it still shows up as a 64 file even though the radio is a 67.
2. So I tried to create a brand new PPS file. Interestingly, PPS doesn't have a model entry for my "exact" model (G5B67BF-SXVXEN1401UNI-0002-180625). There is an entry for G5B67BF-SXVXEN1400, though. Wonder what the difference is. Selecting the 1400 option does seem to make DMR an option.
Dan
Webodisk
Silent key.
Virginia Beach,VA
Go to create profile,then copy from existing profile, select your current profile and on the bottom is covert to a new model then look for a 67 model the has your frequency range
  • Like
Reactions: RRR
mmc-dsm
Please test this as more and more systems are RAS enabled. Also, please consider supporting it and trunking; IMO I think we will see Capacity Max trunking systems (or other TIII systems) popping everywhere in the next years.
K2NEC
5F6
I don't think Capacity Plus systems are going to be going away anytime soon but that is a discussion for another thread.
elrod
R'ville,IL.
Maybe a stupid question but I don't know a thing about DMR.
I do have a G5 dual band 700/800 Vhf 136/174.
Is Dmr Vhf or Uhf and will my G5 be able to receive it.
Chuck
N6ML
DMR, like any other mode, is not really tied to a specific band. Some basic info at Digital mobile radio - Wikipedia. The RadioReference database is a great resource - find your county, and look at the bottom of its page for a list of trunked systems.
buddrousa
Kevin I read it as change your model number to a 6
Dan
Dan read post #1 it states after the dealers get the tool it will be posted on the website for public download.
DanRollman
Atlanta, GA
Not my issue. Post 1 relates to how to change a 64 model to become a 67 model. Reread my post. As noted, I already have a 67 model. My question was only about changing legacy PPS files, not changing hardware models. Anyway, the above posts were great. Thanks to all for the info.
Sent from my BBF100-2 using Tapatalk
DanRollman
Atlanta, GA
I see now Dan have you tried reading the G5 and save the file as a new file name?
Yes I tried that first. That didn't change the model in PPS, so that's why I posted. Webodisk's tip was good. Thanks.
