DMR One Freq.
NP3Z
Utuado,Puerto Rico
Hi , Im trying to setup a DMR One Freq. System .I do all the steps including putting the TG ,Slot etc. but when I put that system to scan in frequency it says 000.000 but it shows as receiving signals but nothing else, no audio ,nothing.I monitor it in conventional mode and i can here a few TG's in that frequency.What could i be doing wrong? thanks
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
What radio and software? What is the one freq system - is it in our database?
Mike
Whiskey3JMC
Surfer of the Delaware Valley Airwaves
Simulcastylvania, TE
How active is the frequency? So if you plug it in manually you do hear voice traffic?
NP3Z
Utuado,Puerto Rico
yes if i put manually i can hear all the traffic with no problem.Im checking now in Proscan and under the tab of digital type it says CON and system type Conventional
Whiskey3JMC
In this case, CON is NOT conventional but rather MotoTRBO Connect Plus. You'll need to program the system as a MOTOTRBO trunked system. Chances are there are other active frequencies in the license that you may be missing. You'll need to determine the other active frequencies in use on the license. Proper LCNs will also need to be entered if the system is unknown to the DB. You'll need to run LCN finder to determine proper LCN order to trunk the system properly. MENU > ANALYZE > LCN FINDER > choose system > choose site. Allow the finder to run until LCNs are found on all active frequencies
