DMR Question
dgoodson
Florida
I noticed that every DMR system I have detected uses "Color Codes" but no other trunked or P25 systems do.
So are Color Codes unique to DMR and will a DMR system always use a CC?
tweiss3
Is it time for Coffee?
Ohio
Yes, it's just the name for DMR's squelch. Analog FM has CTCSS and DCS, while DMR has Color Codes (CC), P25 has Network Access Code (NAC) and NXDN use Radio Access Number (RAN), but they are all just different names for the type of squelch coding used.
popnokick
Northeast PA
Unlike a CTCSS code with an analog system, if you leave the Color Code out of the DMR configuration for a given system / channel you will not get an "open squelch". You'll hear nothing.
