DMR simplex help
XLFCC
If anyone can help me set up a radio to radio DMR set up. Radio 1 is a Boafeng DM32 and radio 2 is a Motorola XPE3500e. Made sure the RX and TX frequencies are the same and made sure the color code is the same (cc:3) and the talk group ID is the opposite radios ID (ex: radio 1 have radios 2 ID and radio 2 has radios 1 ID) for a “private communication”. Encryption is OFF both radios are less then 1 foot away. Tried many different settings on the CPS but no audio is coming from both radios only a blinking receiving LED indicator. Any help will be appreciated.
hill
Middle River, MD
Talkgroup ID needs to be the same to pass audio on simplex. The convention for ham radio simplex DMR is to use talk group 99 for simplex. This ID of 99 would be a group call.
Maybe you were trying radio private call. You would have to list it as private call rather group call.
XLFCC
Let me try ID 99
K9KLC
Southwest, IL
Exactly I'd try to get them to work like this first, TG99, TS1, and CC "whatever" on both. Make sure they'll talk to each other like this first. Make sure TG 99 is "group call". Then worry about the private call stuff after you get them working like this first.
K9KLC
Southwest, IL
Do you have an XPR 3500e or XPE 3500e. Where are you located?? I'm confused by the model number unless that's some European model number. Being in the US I have all XPR series radios, including a couple of 3500e's. Also just for information, what CPS are you using to try and program the Motorola?
Colin9690
County 21
APE282018
A Google search by copy/pasting that leads to no credible results, I'd say he's mistaken on the XPE prefix.
I've never heard of it either.
K9KLC
Southwest, IL
Ya, I tend to think he's mistaken also. I did the same google search just to double check and came up with nothing also.
