DMR Trunking Programming Help
KD2SBJ
I dont know why but I am struggling with Motorola CPS 2.0 in trying to program a DMR Motorola Capacity Plus Single Site (TRBO). I can only find video that are on the old software and its not helping me. If there is anyone that can help me with a step by step that would be helpful or send a video that would be great. Also im will to do a teams session as well. FYI i learn better by doing it as i am a very hands-on learner.
K2NEC
5F6
I have a step-by-step guide in this thread
KD2SBJ
I would also need to TX. Can i send a screenshot if you able to break it down and take that info to put it as an example?
K2NEC
5F6
I'll know how that will go. Either not seeing my radio again or losing all my frequencies.
Then maybe you dont have permission to be on the system and shouldn't be programming it in the first place?
Either way, you've been given instructions on how to passively monitor the system and no one here will teach you how to TX on a system you don't have authorization for.
MTS2000des
5B2_BEE00 Czar
No, that never happens. No one would dare come to a hobbyist website asking for information on how to access a trunking system with no authorization. Naw, never.
wa8pyr
Staff member
Lead Database Admin
Ohio
If the system owner/operator is that disreputable, maybe you should find a new system….. or one you’re authorized to be on.
And there's probably a reason for that.
The FCC rules are exceedingly clear on this.
No one can add a radio to a Part 90 radio system without permission of the licensee. Does not matter if you have an amateur radio license, work for the company, contract for the company, know someone who works there, or "just in case". Rules are clear. You are not the licensee of this system. Unless you have direct, written permission from them, you should not be adding their system to your radio.
§ 90.427 Precautions against unauthorized operation.​
(a) Each transmitter shall be so installed and protected that it is not accessible to or capable of operation by persons other than those duly authorized by and under the control of the licensee. Provisions of this part authorizing certain unlicensed persons to operate stations, or authorizing unattended operation of stations in certain circumstances, shall not be construed to change or diminish in any respect the responsibility of station licensees to maintain control over the stations licensed to them (including all transmitter units thereof), or for the proper functioning and operation of those stations and transmitter units in accordance with the terms of the licenses of those stations.​
(b) Except for frequencies used in accordance with § 90.417, no person shall program into a transmitter frequencies for which the licensee using the transmitter is not authorized.​
Paragraph B makes it clear, you, as a ham, are not the licensee of this system, and you should not be programming radios to transmit on a system that is not yours.
This is why many of us run trunked systems, to keep people out that do not belong on the system. It's also one of several reasons we run encryption.
Avoid giving the hobby a black eye. Resist the urge. If you have a legitimate need to be on this radio system, you need to do it properly.
