DMRVA Amateur Radio Network ?
JCar24
Does anybody know if this system appends correctly in sentinel for the sds100 with dmr upgrade?
I spent the last couple of days in Front Royal, I brought my scanner along, deliberately trying to hear the repeater in Warren Co. (443.1625)
I have the system loaded in the scanner as its own favorite list, but I never picked anything up.
I have the frequency loaded into a bc125at, I can hear the dmr sound frequently in Warrenton.
Thanks in advance for the response.
Whiskey3JMC
Chimer Inner
Out of Area 🇺🇸
And you have at least one talkgroup programmed into the FL? Is the FL set to "on" via Menu > Set Scan Selection > Select Lists to Monitor? If you set quick keys at the system, site and/or department level these need to be turned on as well. At least one talkgroup needs to be programmed in otherwise the system will be omitted if you don't have ID search turned on
N4VKF
SPOTSYLVANIA,VA
The system these days does not have the traffic that it used to. Not all of the talkgroups are active full time on the repeater. Some are only
PTT activated and timeout 15 mins after they are PTT activated by the repeater user.
JCar24
Thank you
N4VKF
SPOTSYLVANIA,VA
The word is that a new UHF repeater will be activated in Middlesex County this month and a new Vhf repeater in Franklin County soon.
