Do NOT use Diamond SRH77CA on SDS100
jonwienke
More Info Coming Soon!
VA
Indoors, weather can be a significant factor, as well as solar activity, foliage development on trees, and a bunch of other factors.
tumegpc
Southern Oregon
Are anyone using their expensive scanner outside in the rain, without an umbrella and holding it in your hand and not protected inside their jacket?
Why did Uniden think that we want to use a scanner in pouring rain so that they had to make it less user friendly with o-rings at the non-standard antenna and a funky bubble keypad and making special arrangement to not trap condensation inside the scanner? Who requested a watertight scanner? Jacques Cousteau with his underwater explorations?
/Ubbe
Uniden listens ? When was there an outcry for the next scanner to be water resistant ? And how many of us said okay to losing the use of 99% of our favorite SMA antennas that we've used for years with the 396XT and 436HP's?
Something is wrong when you have users modifying there $20-30 SMA antennas just so it will fit the SDS100.
Ubbe
Stockholm, Sweden
...Not sure this data means anything because I can watch the RSSI fluctuate significantly while signal is active....
Remember that the SDR receiver chip in the SDS100 are designed to receive tv signals that are 5-10MHz wide, not 25KHz. The manufacturer Rafael recommends the chip for digital terrestial and cable tv.
My SDR usb sticks reacts to any strong signals withing a few MHz that'll raise the noise floor and burries the carrier signal in the noise and if it is set to AGC the received signal level jumps around like crazy.
The specification for the SDR chip says it's using an internal power detector to adjust the gain of its front end amplifier. Only the IF sections gain can be controlled from an external source.
I have no idea how Uniden have solved this to be able to only let the internal power detector see the signal level from a 25KHz bandwidth and not from adjacent frequencies within 5MHz. Maybe it's a hardware limitation and are unsolvable, lets hope not, and could be the reason why there are some strange signal level behaviour from this scanner.
/Ubbe
jonwienke
VA
How soon we forget. Using SMA antennas has always been problematic. There has never been a standard for how far the SMA connector should protrude from the body of the radio, so some antennas fit OK, some antennas didn't make electrical contact because they couldn't screw on far enough, and still others bottomed out on the SMA connector before contacting the radio body, leaving a gap between the antenna base and the radio, looking like crap, and greatly increasing the risk of breaking the SMA connector, unless you could find a washer of the correct thickness. The SDS100 has simply changed the mix of SMA fitment issues encountered.
Using BNC antennas has always been faster and more convenient to change antennas (no cross-threading,1/4-turn of locking collar to attach or remove), standardizes base, mobile, and handheld antennas on a single connector, eliminates the SMA fitment issue (as long as the adapter matches the radio you're good), and reduces wear on the radio itself (the SMA connector only gets wear when you change adapters, not antennas).
jonwienke
VA
A mix of things and and the scanner hasn't moved in about 5 days, but we have changing weather and other factors. Not sure this data means anything because I can watch the RSSI fluctuate significantly while signal is active (I didn't pay enough attention to know if same behavior with the stock antenna). The log only shows the RSSI value at the point when the signal ended so I guess YMMV. Maybe SDS100 behavior or signal interference issues. I'll take a snapshot of new data after a couple days of history to compare.
Your comparison is only valid if you compare the same set of frequencies before and after. If the new antenna picks up additional freqs that the old one did not, then the new freqs will skew the average and make it look like the new antenna is performing poorly when the opposite is true.
KD9KSO
Midwest
Not trying to imply the antenna doesn't work. Rather, so far, I can't see a benefit. Maybe real test is when I'm traveling through local cities and towns.
--Edit: and I'm new to scanning 3 weeks ago...
Here's a slice of recent entries:
TGID Freq Digital Type System Type RSSI UID Mod. Hits Duration Start time End Time System/site - Dept - Channel
23184 Motorola -77 25352 NFM 297 00:19:06 06/22/18 18:26:55 06/26/18 21:13:36 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - Valley Communications - ValCom Spec1
23152 Link Motorola -71 25401 NFM 4712 06:02:29 06/22/18 18:25:56 06/26/18 21:12:22 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - King County Sheriff - KCSO N
18544 Link Motorola -102 20889 NFM 1101 00:53:28 06/22/18 18:23:41 06/26/18 21:11:54 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - Redmond - Red PD Disp
21424 Link Motorola -69 23323 NFM 2962 02:58:11 06/22/18 18:25:14 06/26/18 21:11:35 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - NORCOM - NC Pol 1
23344 Link Motorola -69 26981 NFM 1224 01:12:23 06/22/18 19:15:43 06/26/18 21:11:01 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - King County Sheriff - KCSO NW
23280 851.9625 Link -73 25938 NFM 2487 01:24:07 06/25/18 13:39:00 06/26/18 21:13:58
23216 Link Motorola -70 24073 NFM 2242 01:21:59 06/22/18 18:54:57 06/26/18 21:09:35 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - Seattle Police - SPD Cmnd 1
19472 Link Motorola -106 21470 NFM 2604 02:35:32 06/22/18 18:32:14 06/26/18 21:07:44 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - NORCOM - NC Pol 2
59208 774.8062 P25 P25 Trunk -87 7503924 NFM 682 01:20:25 06/22/18 18:23:32 06/26/18 21:07:19 WA State Patrol - King Lake - WSP District 2 - WSP Seattle N 710
23312 Link Motorola -74 25073 NFM 255 00:30:59 06/22/18 20:45:58 06/26/18 21:02:31 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - King County Sheriff - KCSO Tac 4
3728 Motorola -82 46255 NFM 34 00:05:08 06/22/18 20:24:13 06/26/18 20:55:23 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - Seattle Police - SPD Tac W
18928 Link Motorola -73 18551 NFM 765 00:37:57 06/22/18 18:37:20 06/26/18 20:53:11 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - NORCOM - NC Pol 3
32784 Link Motorola -78 29833 NFM 132 00:10:01 06/22/18 21:08:16 06/26/18 20:50:32 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - Duvall - Duv CityWide
4304 Motorola -102 47493 NFM 24 00:02:21 06/26/18 18:16:43 06/26/18 20:43:55 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - Seattle Police - SPD CIS 2
59202 769.9687 P25 P25 Trunk -91 7501906 NFM 16 00:02:14 06/22/18 23:56:56 06/26/18 20:34:46 WA State Patrol - King Lake - WSP District 2 - WSP Car 2
59209 769.7187 P25 P25 Trunk -91 7503924 NFM 1119 02:25:45 06/22/18 18:27:27 06/26/18 19:56:11 WA State Patrol - King Lake - WSP District 2 - WSP N King N 710
37072 Link Motorola -67 38132 NFM 85 00:06:28 06/23/18 01:36:39 06/26/18 19:38:06 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - Des Moines - Des PD Tac
37520 Link Motorola -91 36898 NFM 186 00:10:22 06/22/18 20:57:03 06/26/18 19:28:08 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - Valley Communications - ValCom Spec2
37168 Link Motorola -74 36457 NFM 254 00:20:52 06/22/18 19:21:53 06/26/18 19:14:19 Seattle-King County Public Safety (KCERS) - King County/ValleyCom Simulcast - Kent - Kent PD Tac
It was designed for 2M/70CM operation. It will not be optimal across the entire electromagnetic spectrum.
tumegpc
Southern Oregon
Then why does Uniden , Icom, Kenwood and Yaesu use SMA connectors if they are so "problematic"?
The problem is Uniden's design of the SDS100 to meet water resistant specs.
Jon, are you serious ? The BNC adapter that comes with the SDS100 make its more difficult and inconvenient to use. You even recommended someone to "Get a lathe!!!" so they can modify their SMA antennas.
jonwienke
VA
Each manufacturer uses a different protrusion dimension, even from model to model (Uniden is not the only one guilty of this), which the antenna needs to match to fit properly. It's one way to "encourage" users to use the manufacturer's antenna, while still nominally adhering to a standard. Thank you for making my point for me.
The SDS100's SMA connector protrudes from the radio body less than other models. There is no standard that specifies how far it should stick out. See my first comment.
Absolutely. Some of the factory BNC adapters fit tightly. You just have to tighten the adapter on the SMA connector a wee bit tighter, so it doesn't unscrew when changing antennas.
As for the lathe comment, that was in reference to the guy who dremeled the base of his SMA antenna. Not exactly the best way to get the dimensions right for optimal fit, and not very aesthetic, either. If you're going to modify an antenna to get the fitment correct, a lathe is the right tool for the job, not a Dremel. But that is hardly the same as saying only SMA antennas should be used.
bob-k
Colfax NC
Oh Really?
Phooey!
5 minutes with a Dremel and problem solved!
Sent from my SM-G935V using Tapatalk
What is what looks like a metal band? Being this is brand new I eat it if it is defective, yet I may try it as I prefer the tighter fit of SMA. So you modified yours instead of getting a same antenna w/BNC.
Markb
Planet Earth
Yes. The metal band is the unpainted metal that I ground down so that the antenna will fit.
Valeriy
European Union
Why did Uniden think that we want to use a scanner in pouring rain so that they had to make it less user friendly with o-rings at the non-standard antenna and a funky bubble keypad and making special arrangement to not trap condensation inside the scanner? Who requsted a watertight scanner? Jacques Cousteau with his underwater explorations?
/Ubbe
On July 27, 2017, in the afternoon I saw the worst Summer shower ever, and I was out and about with my 436 in a belt case.
My 436 survived, but I definitely didn't like the risk to ruin it...
I think all the handheld devices such as scanners, transceivers, mobile phones, navigators, etc.
should be built to comply with military-grade specs.
radio3353
I think all the handheld devices such as scanners, transceivers, mobile phones, navigators, etc. should be built to comply with military-grade specs.
:lol::lol: And people complain about the $650 price tag! Seriously :confused:
cvbart
You folks are the best. Just got my SDS100 and you solved my problem with the Diamond SRH77CA. And another thread explained how to keep the backlight on. You all make this easy.
SMBaugh2
Georgia on my mind
The problem is Uniden's design of the SDS100 to meet water resistant specs. I love my SDS-100 but this statement is what bothers me. The fact that now all of my SMA antennas will not work with my SDS-100. But I can use my BNC antennas. How ever I will say also that having my scanner somewhat weather proof and I don't have to worry about hiding it in the rain and worrying about it getting wet is nice to have too. So the moral of this story is you just cannot have everything.
justabigham
Auburn, WA
RH77CA arrived today.
History logging data says meh for this antenna, but still too early for final judgement:
Average RSSI before RH77CA (using stock SDS100 antenna): -65.48958333 (3 days of data)
Average RSSI after RH77CA: -77.44444444 (3 hours of data)
The jury is still out.
Looks like RH77CA is worse for you. Where exactly are you located in the Seattle area? I live fairly close to the KCVC site and have much better RSSI numbers
