Do truckers still use CB Radios?
jcrmadden
Ck ferrule.
I’d figure it may be “broken” at that point unless you have correct spring
I had removed the spring a good while back.
The wind load on that seven footer was too much to run the spring (even with the HD barrel spring it laid back way too far).
The ferrule and everything looks fine. Nothing loose, SWR still great, RX and TX still top shelf.
Did have some memory in it when I first got her loose (expected given that it spent a week like that).
I put the sweep facing forward and it's already back to normal.
