OP25 Docker Image Created / Looking for Testing
NebraskaCoder
Omaha, NE
The buffered stderr had me scratching my head for quite a while. What a crazy decision on the part of the python developers!!
I didn't even know about the buffer since I hadn't had a chance to use stderr (was mostly doing django). I did some research and I can see how that is a problem in OP25 haha.
Looks like there might be another error with the HTTP interface.
The first error is osmosdr source_c creation failure with the full error being:
Python:
gr-osmosdr 0.2.0.0 (0.2.0) gnuradio 3.8.1.0
built-in source types: file osmosdr fcd rtl rtl_tcp uhd miri hackrf bladerf rfspace airspy airspyhf soapy redpitaya freesrp
Traceback (most recent call last):
  File "./rx.py", line 1028, in <module>
    rx = rx_main()
  File "./rx.py", line 937, in __init__
    self.tb = p25_rx_block(self.options)
  File "./rx.py", line 145, in __init__
    gain_names = self.src.get_gain_names()
AttributeError: 'NoneType' object has no attribute 'get_gain_names'
The full command is ./rx.py --nocrypt --args "rtl" --gains 'lna:36' -S 960000 -X -q 0 -v 1 -2 -V -U -T trunk.tsv -l "http:0.0.0.0:8080" 2> stderr.2
boatbod
Talbot Co, MD
Python:
    rx = rx_main()
That error normally happens when gr-osmosdr cannot find the sdr hardware. Does the rtl device show up when you run "lsusb" command?
NebraskaCoder
Omaha, NE
Actually, I'm getting this error now:
Python:
Exception while serving /
  File "/usr/lib/python3/dist-packages/waitress/channel.py", line 349, in service
    task.service()
  File "/usr/lib/python3/dist-packages/waitress/task.py", line 169, in service
    self.execute()
  File "/usr/lib/python3/dist-packages/waitress/task.py", line 477, in execute
    self.write(chunk)
  File "/usr/lib/python3/dist-packages/waitress/task.py", line 330, in write
    channel.write_soon(towrite)
  File "/usr/lib/python3/dist-packages/waitress/channel.py", line 320, in write_soon
    self.outbufs[-1].append(data)
  File "/usr/lib/python3/dist-packages/waitress/buffers.py", line 249, in append
    self.strbuf = strbuf + s
TypeError: can't concat str to bytes
boatbod
Talbot Co, MD
Fixes posted and available in origin/master (as well as origin/dev). I've tested the gui commands and fixed a couple non-python3 bugs I ran across along the way.
If anyone has a suitable testing environment with the ability to make an apples-apples comparison, I would be curious to compare CPU utilization of op25 under gr3.8/py3 versus the same hardware & configuration running on gr3.7/py2.
As an aside, my test environment is happily running an Airspy @ 3.0Mhz with glitch-free audio via the much-maligned 'pulse' subsystem on Ubuntu 20.04 in a virtual environment using Virtualbox on host Mint 18.3 (Ubuntu 16.04).
NebraskaCoder
Omaha, NE
I have VMWare workstation, so I can create two VMs to do testing on the same CPU(s). I'll do Ubuntu 18.04 and Ubuntu 20.04 for testing.
