SDS100/SDS200: Does This Indicate Data?
JASII
Memory Capacity
So, when I check the History Log and see this entry, with no Talkgroup ID or UID, is it likely data being sent, this no voice TGID or UID?
This is from a Uniden SDS100.
462.200000R 60-120NFM3700:00:0202/23/21 09:01:3802/23/21 09:01:40Digital Search 6.25 Khz - Digital Search 6.25 Khz - 462.200000MHzConventionalIDS
sonm10
Central MN Monitor
Sauk Centre, Minnesota
I dont have any Idas systems to confirm, but dont they have a blip of data every few seconds such as Cap+?
Also, I see the signal strength is quite weak , -120, so could be false decode.
Just curious, the 37, is that the hit counter?
Ubbe
Stockholm, Sweden
My experiance from Uniden scanners are that IDS are the most common false decode of conventional analog transmissions. At -120dBm the squelch are just opening up with a lot of noise, so the risk of false decode are high.
/Ubbe
JASII
Memory Capacity
That is good to know Ubbe. I do have a bunch of them in various modes. Generally speaking, IF I have activity with BOTH a Talkgroup ID and UID, particularly if it is more than once, it is usually legitimate. The challenge, of course, is separating the valid from the invalid entries!
464.475000CC 14-106NFM13800:00:0402/24/21 07:53:1502/24/21 08:13:41Digital Search 6.25 Khz - Digital Search 6.25 Khz - 464.475000MHzConventionalCAP
462.200000R 39-110NFM3800:00:0402/23/21 09:01:3802/24/21 06:58:58Digital Search 6.25 Khz - Digital Search 6.25 Khz - 462.200000MHzConventionalIDS
462.050000/1CC 2-120NFM400:00:0202/24/21 02:08:2302/24/21 02:08:25Digital Search 6.25 Khz - Digital Search 6.25 Khz - 462.050000MHzConventionalXPT
462.350000/2CC 4-115NFM400:00:0202/24/21 00:37:5502/24/21 00:37:57Digital Search 6.25 Khz - Digital Search 6.25 Khz - 462.350000MHzConventionalXPT
463.775000R 35-120NFM300:00:0202/23/21 07:58:2102/23/21 07:58:23Digital Search 6.25 Khz - Digital Search 6.25 Khz - 463.775000MHzConventionalNX4
454.775000N 4E6-120NFM1300:00:0202/22/21 23:34:2202/22/21 23:34:25Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.775000MHzConventionalData
463.818750R 14-120NFM3500:00:0202/22/21 19:56:4702/22/21 19:56:49Digital Search 6.25 Khz - Digital Search 6.25 Khz - 463.818750MHzConventionalIDS
451.650000/1CC 10-107NFM1100:00:0202/22/21 17:18:1802/22/21 17:18:20Digital Search 6.25 Khz - Digital Search 6.25 Khz - 451.650000MHzConventionalCAP
454.537500R 2-120NFM500:00:0202/22/21 16:48:4902/22/21 16:48:51Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.537500MHzConventionalNX4
464.800000R 2-111NFM38300:00:0202/22/21 14:40:4902/22/21 14:40:51Digital Search 6.25 Khz - Digital Search 6.25 Khz - 464.800000MHzConventionalIDS
454.131250R 1-118NFM500:00:0202/22/21 14:29:1602/22/21 14:29:18Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.131250MHzConventionalNX4
454.081250R 2-103NFM1100:00:0202/22/21 12:53:3302/22/21 12:53:35Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.081250MHzConventionalNX4
454.518750R 2-119NFM400:00:0202/22/21 11:51:0602/22/21 11:51:08Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.518750MHzConventionalNX4
454.525000R 2-115NFM200:00:0202/22/21 11:41:5302/22/21 11:41:55Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.525000MHzConventionalNX4
454.531250R 32-120NFM500:00:0202/22/21 11:37:2802/22/21 11:37:30Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.531250MHzConventionalIDS
454.543750R 2-120NFM400:00:0202/22/21 11:34:5702/22/21 11:34:59Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.543750MHzConventionalIDS
454.556250R 1-120NFM200:00:0202/22/21 11:34:0702/22/21 11:34:09Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.556250MHzConventionalNX4
454.143750R 1-120NFM100:00:0202/22/21 10:13:4502/22/21 10:13:48Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.143750MHzConventionalNX4
454.450000N 4E6-114NFM1600:00:0202/22/21 09:41:0902/22/21 09:41:11Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.450000MHzConventionalData
454.550000N 4E6-107NFM10000:00:0202/22/21 09:28:3002/22/21 09:28:32Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.550000MHzConventionalData
451.975000N 4EB-120NFM2700:00:2702/19/21 11:10:1002/22/21 08:55:55Digital Search 6.25 Khz - Digital Search 6.25 Khz - 451.975000MHzData
454.137500R 1-120NFM1100:00:0402/20/21 07:05:4102/22/21 07:59:10Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.137500MHzConventionalNX4
454.600000N 4E6-102NFM800:00:0202/22/21 07:52:5702/22/21 07:52:59Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.600000MHzConventionalLink
463.937500CC 4-120NFM3000:00:0402/19/21 14:38:4202/22/21 07:28:55Digital Search 6.25 Khz - Digital Search 6.25 Khz - 463.937500MHzXPT
454.250000R 2-120NFM22100:00:0202/22/21 06:31:0902/22/21 06:31:11Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.250000MHzConventionalNX4
454.018750R 1-111NFM15800:00:0202/22/21 05:24:1202/22/21 05:24:14Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.018750MHzConventionalNX4
464.925000/2CC 10-120NFM2600:00:0202/21/21 23:48:5302/21/21 23:48:55Digital Search 6.25 Khz - Digital Search 6.25 Khz - 464.925000MHzConventionalCAP
454.025000R 1-111NFM15000:00:0402/20/21 07:08:4002/21/21 20:06:43Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.025000MHzConventionalNX4
452.000000/2CC 10-120NFM5600:00:0402/19/21 14:21:5402/21/21 19:47:47Digital Search 6.25 Khz - Digital Search 6.25 Khz - 452.000000MHzCAP
454.087500R 61-120NFM23900:00:1502/20/21 05:56:0802/21/21 16:17:43Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.087500MHzConventionalIDS
454.168750R 2-96NFM23400:00:0602/20/21 13:32:2202/21/21 16:15:18Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.168750MHzConventionalNX4
452.225000/1CC 10-105NFM17200:00:0202/19/21 13:04:3502/21/21 15:11:04Digital Search 6.25 Khz - Digital Search 6.25 Khz - 452.225000MHzCAP
451.262500N 4E6-120NFM18900:00:2302/19/21 11:06:0802/21/21 13:11:17Digital Search 6.25 Khz - Digital Search 6.25 Khz - 451.262500MHzData
454.175000R 2-109NFM16900:00:0402/20/21 08:00:4402/21/21 12:39:22Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.175000MHzConventionalNX4
464.625000/2CC 14-105NFM200:00:0302/19/21 12:07:1502/21/21 11:42:57Digital Search 6.25 Khz - Digital Search 6.25 Khz - 464.625000MHzXPT
454.031250R 4-120NFM9700:00:0202/21/21 10:27:5402/21/21 10:27:56Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.031250MHzConventionalNX4
464.737500CC 9-120NFM400:00:0302/19/21 14:06:5702/21/21 10:00:34Digital Search 6.25 Khz - Digital Search 6.25 Khz - 464.737500MHzCON
464.600000CC 9-107NFM400:00:0202/21/21 09:36:5002/21/21 09:36:52Digital Search 6.25 Khz - Digital Search 6.25 Khz - 464.600000MHzConventionalCON
451.075000/1CC 0-120NFM13100:00:1602/18/21 10:04:5302/21/21 08:45:30CAP/CON/DMR/DT3/XPT - Active Color Code 0 - DairylandConventionalDT3
454.093750R 2-96NFM31800:00:0202/21/21 08:37:0002/21/21 08:37:03Digital Search 6.25 Khz - Digital Search 6.25 Khz - 454.093750MHzConventionalNX4
GTR8000
NY/NJ Database Guy
BEE00
I wouldn't trust any of those hits, as they are all very short bursts with awful signal strength below -100 dBm. If you are truly interested in sniffing out signals like this, you really need to improve your monitoring situation.
JASII
Memory Capacity
...If you are truly interested in sniffing out signals like this, you really need to improve your monitoring situation.
What, specifically, are you referring to? Are you thinking of a better receiver, antenna or feedline?
GTR8000
NY/NJ Database Guy
BEE00
Improve your reception/signal. Without a reliable signal on these hits, you're never going to get reliable results.
