While Ft Worth PD is encrypted, Ft Worth Fire and many of the other agencies on NTIRN are not. From your location, you likely can hear many of them.I am in downtown Fort Worth with an SDS 200 and a decent antenna. Besides unencrypted NTIRN ... what else could I be scanning? How would 'you' setup in this scenario?
Thanks!
Dang, I wish we had a 1/10 of that here. We have one short line here, and they can't come up my way now because our recent hurricane smoked the river crossing bridges.Forth Worth also is a major railroad hub. If that interests you, check the listings here.
If you have the DMR upgrade, I would suggest that you scan the Megahertz trunked system. More specifically, listen to CareFlite on that system. That's one of the air medical services that cover this area. There are a couple of other Medevac conventional channels that you might hear.
And, of course, aircraft. While you likely would not be able to hear the tower at DFW Airport, you can monitor the aircraft in the air landing & departing, along with Approach & Departure frequencies. The Joint Reserve Base would also be in range, at least for airborne aircraft.
Depending on your location (in other words, if you are staying in one of the hotels several stories up), you might also be able to hear some of the Dallas PD & FD activity. Dallas, as well as Dallas County, are in the process of shifting to NTIRN, but their conventional channels (Uhf for Dallas, Vhf for Dallas County) are still in use & active. You might also be able to pick up the Parker County trunked system.
Try this conventional license:I am about 10 floors up facing east, southeast. I can pickup all the FW (non Police) channels and the smaller cities/towns around downtown with ease (White Settlement, Benbrook, Sansom Park, River Oaks, etc). Those are some good listening when they turn into an Interop situation.
I will try turning on the RR service, good idea.
What I am really interested in is listening to the 'Sundance Square Security' aka 'Bass Police' which I have loaded from the RR database, but I never get any hits. I just wonder what other frequencies are in use in my immediate area.
Thanks for your input!
Then it likely is this one:Bass security is 800 MHz DMR conventional. I forgot the frequency, but it is one of those in the FCC list that Heigtx posted.
You might be better off to enter it as an OFT system, with each frequency as a separate 'site', and set it to ID Search to sniff out other TGIDs.
Interesting.It's kinda scary the number of times a plane departing DFW declares an emergency for fire or smoke or something else.
Very interesting. Thanks!Try the two federal prison hospitals...Carswell and Ft Worth. Quiet most of the time, but prisoner moves, outside transports and facility security has been pretty interesting when they do utilize the radio.
Is there a tutorial that shows how to do this? Thanks!
Laptop with Sentinel and ProScan.A
Are you programming just through the key, or do you have a laptop or other PC where you can use Sentinel?
Several options:Laptop with Sentinel and ProScan.
Several options:
You can use use ProScan to import the trunked system into a Favorites list. (Or, you can append it from the main database in sentinel.)
Once imported (or appended), then I would edit the system (either in Sentinel's Favorites list editor, or in ProScan) to change the system to ID Search instead of ID Scan. (In Sentinel, you do that by turning ID Search on. That's under the Options tab in Sentinel.
If editing in ProScan, then select the system, and you'll see a checkbox to turn ID Search on.
Be sure & save your changes before downloading to the scanner.
If you also want to set it up as a One Frequency Trunked System, you can do that either in ProScan, or in Sentinel. I'll illustrate using ProScan, but the procedure is basically the same in Sentinel.
In ProScan, be sure that the Favorites list you want to use is selected. Then click the 'Add System' menu
Select DMR One Frequency.
With the system created (and named), select Add Site.
.After adding a site, then with the site selected, click on Add Frequency. Enter each frequency as a single site (within the OFT system).
For simplicity, I use the frequency as the name for it's site in an OFT system.
You can set the Color Code to 0 (zero) which is how it is listed in the database, or leave it as Search to verify if the zero is correct,
With all four frequencies (in their respective sites) added, select the Add Department.
Give the Department a name. Then, select Add TGID to add a talkgroup.
Ideally, if the database is correct, then you'll hear the system using the DMR trunked system as listed. But just in case, with the OFT system in place, you have a backup method to catch activity.
Of course, if you do find, and can verify the usage of any new talkgroups, be sure & submit that to the database.
For the conventional frequency that jason mentioned above, you can set it as a priority.
That's 857.5375.![]()
FCC Callsign WPJX426 (BASS ENTERPRISES PRODUCTION COMPANY)
FCC Callsign WPJX426 (BASS ENTERPRISES PRODUCTION COMPANY)www.radioreference.com
You can create a conventional system, in either ProScan, or Sentinel. Here's a look at ProScan:
I would, at least initially, leave the Audio type as 'Search'. That frequency is licensed for both analog, as well as DMR. Leaving it, initially, as Search, will let the scanner receive it no matter which way it's used. If you see activity, then you'll see the Color Code (if used as DMR), or the PL (or DCS) if it is used as an analog channel. Since their trunked system is DMR, I would expect that is how it would also be used, Here again, though, if it is used as DMR, then I would create an OFT system for it, in case they also use talkgroups.
I just went & looked at your alerts and I overlooked what you had set::Like this?
My alert light settings do not seem to be working. Not sure what I am doing wrong there. At least I can hear them though!!
That. sort of, confirms my suspicion on the Bass trunked system in the database. You're seeing TGIDs 13 & 16, on the OFT channels. and also showing color code 9. While 0 (zero) is a valid color code, I suspect that somebody may have submitted the system without verifying the color. Or, it's also possible that Bass changed the code after the system was created in the database.I have been getting hits on the new Bass OFT system, but not the RR DB system. FWIW the OFT is hitting on Color Code 9 and (so far) I see TGID 13 and 16.
The scanner will check the system & determine the LCNs for each frequency. If the system is relatively busy, it should find at least a couple fairly quickly. But, say, late night, when nothing much is going on, it mightnot get to all of them. The frequency has to be in use for Analyze to see which LCN applies. This probably would do better during a normal business day. Once it finds all of the LCN's, or at least a couple, exit Analyze & be sure to select 'save' for what it finds.
I would then read the scanner back into Sentinel (or ProScan) so that you can see what the LCNs found are. If it did not see a specific frequency used, that will show 0 for the LCN. If you se, say, 1 & 3 'found', and that matches what is in the database, then probably the LCNs listed were correct. Note, however, if it found, and you saved, say 2 of them, but then you run Analyze/LCN Finder again, it will change all the LCNs tzero before starting over, so that would wipe out the "LCN 1 & LCN 3 that you found initially.
When you start the LCN Finder, it resets all of the LCNs on your target system to zero. I presume that where you are seeing LCN 1, 2, 3, and 4 is on your programming file. If you "read" the scanner back into Sentinel, you should get a prompt that the list being read is different than in Sentinel, and choose whether to replace the item in the list in Sentinel, save it with a new name, or cancel (ignore) the change. You want to let it replace what is in the software so that you can view what it found.Using the RR DB 'Bass Enterprises' (MotoTRBO) system ONLY:
I changed the CC to 'search' for all 4 of the freqs and ran Analyze/System Status. CC 9 was the only one that popped up.
I then changed all the CC fields to 9 on all 4 freqs and started the Analyze/LCN Finder. It did not find any LCNs. (They are still 1,2,3,4 in my settings - was I supposed to set them to 0 (zero) first?
Also, I cannot hear any voice traffic on this system... like I can on the OFT system.
