When you start the LCN Finder, it resets all of the LCNs on your target system to zero. I presume that where you are seeing LCN 1, 2, 3, and 4 is on your programming file. If you "read" the scanner back into Sentinel, you should get a prompt that the list being read is different than in Sentinel, and choose whether to replace the item in the list in Sentinel, save it with a new name, or cancel (ignore) the change. You want to let it replace what is in the software so that you can view what it found.
When you run the System Analyzer, are you seeing any indication of a signal, like you see here? (After you updated the Color Code to 9?) And do you see anything after System Status? The Con + you see on this example is shorthand for Connectivity Plus, which is one version of a DMR system.
And you are seeing those two TGIDs on one of the "OFT" system's sites? Are they all popping uo in the same OFT channel? Or are you seeing more than one frequency come up?
You might connect the scanner to your laptop, putting the scanner in serial mode. Then, use ProScan to capture a log of what it is seeing.
No, this is all I get on the System Status when I run the 'Bass Enterprises' system from the DB.
Here is some of the info from the two different TGIDs I have captured from the OFT system. I named the TGIDs 'Bass 13' and 'Bass 16'. Is there a specific log format that would help you to help me? Thanks!
13 855.587500/1 CC 9 5 8002 NFM 66 00:00:23 02/24/23 18:50:11 02/24/23 18:50:35 Bass OFT / 855.587500 Bass/Sundance Square Bass 13 DMR One Frequency DMR Security - -
16 856.537500/1 CC 9 5 2003 NFM 69 00:00:07 02/24/23 18:31:23 02/24/23 18:31:31 Bass OFT / 856.537500 Bass/Sundance Square Bass 16 DMR One Frequency DMR Security - -
