DPS Radio Issues?
radiochuck
Traffic Reporter
Phoenix, AZ
Anyone know what's up with DPS radio?
I haven't heard a blip out of AZ WINS a couple of hours and UHF has intermittent carrier. Haven't heard any voice traffic in a bit.
rpgaun
Sun City, Az
I’m getting the same thing here on several different frequencies. Have not heard a thing all day on UHF, I’ll crank up the AWINS radio and check that out.
KG7LER
Wittmann, AZ
I was getting ready to pull out another radio to listen on UHF as I was hearing the same in my truck, I was thinking I had a radio problem at first.
radiochuck
Traffic Reporter
Phoenix, AZ
Has anything rather major that you know of happened? Maybe they switched to an encrypted channel for a while
Not likely. I can still hear some very noisy traffic on the UHF channels, but can only hear Metro Central, Metro East and a very noisy Metro West from my location off of the 51 and Northern Ave. The normal traffic is trying to break through the interference.
rpgaun
Sun City, Az
If anyone has O Deck programmed check that. If they are off the air for some reason for system maintenance (?) perhaps the Phx area districts are using O or H Deck. I know in the past LO agencies have used O while there system were being worked on…
radiochuck
Traffic Reporter
Phoenix, AZ
Same thing seems to be happening again today, minus the squelch tail on the UHF/analog. Not a blip off of WINS/Shaw Butte.
JethrowJohnson
I love P25
Marietta OH
It could be anything. I'm just not sure what. Unfortunately, I can't receive another site from this location. I don't get much of the UHF from here either.
I'm not sure, but I'm wondering if maybe they're switching to other channels that maybe aren't in the database whenever this happens.
clover509
Hi, radiochuck,
Monitoring AZWINS on the Thompson Peak site from Anthem. Seems to be normal traffic so far, mostly DPS and DOT comms today. Not hearing much on the conventional UHF side, though.
radiochuck
Traffic Reporter
Phoenix, AZ
@clover509 Interesting. Maybe it's just a Shaw Butte issue. I'm monitoring the full database and still not a peep. Same with the other radios on faves lists. Unfortunately, we don't have a good outdoor antenna, so Shaw is all I can get. That's usually great from here though, since it's just up the road.
