DSD 1.4 and mbelib 1.2.3 released
D
DaveNF2G
Guest
Go to your other post, click on the Report button (the exclamation point within a red and white triangle) in the upper right corner, and put your request for deletion in the comment box.
jcardani
Orlando, FL
Code question to invert NXDN48 voice in DSD 1.4.X Linux version
Hi All,
I normally use my ICOM radio discriminator for input to the soundcard but today I decided to try my PSR-800 and found that its discriminator yielded a better error rate with DMR voice and also with the DMRdecode Java program. However the PSR-800's discriminator is inverted vs. the ICOM. I used the -xr switch for DMR.
However there is no invert switch in DSD for NXDN. Where in the code would be the best place to invert the data so I can build my own invert switch. There's many places to do this but where would be the best (symbol, sample, dibit?) Can I do a simple value = ~value somewhere to invert? But it's probably more complicated.
thanks
slicerwizard
Toronto, Ontario
Because one isn't needed?
Right here:
Code:
 result = read (opts->audio_in_fd, &sample, 2);
 sample = -sample; // invert (don't ask...)
Well, bitwise inversion wouldn't be my first choice...
jcardani
Orlando, FL
Hi Andy,
I actually used result = ~result and now the PSR800 is working with DSD for NXDN48! Thanks for the correct location! Audio is much better using the PSR800 discriminator vs. ICOM R-7000 or 8500.
So it was:
result = -result; // invert
Joe
hatzolahCW
NY
nxdn trunking
Is their any software to decode NXDN trunking system with encryption?
