dsd+2.347 setup
Kentuckyjoe
Hello everyone my name is joe
just bought and downloaded dsd+ 2.347 was needing some help on it .I added all the necessary files and got it to come up
but all it is dong is saying
DSD+ 2.347
Current working directory is "C:\Users\Entertainment\Desktop\DSDPlus modified\UHieViYe7e_DSDPlus2p347"
DSDPlus -h for help summary
Appending synthesized audio to file '1R-DSDPlus.wav'
Assuming FMPA/FMPP/FMP24 is signal source; auto polarity detect is disabled
audio output device #1 = 'LG TV-4 (NVIDIA High Definition'
audio output device #2 = 'Speakers / Headphones (Realtek '
audio output device #1 (LG TV-4 (NVIDIA High Definition) initialized
P25 data loaded; 0 networks, 0 sites, 0 channels
0 frequency records loaded
23 radio records loaded
1 group record loaded
0 site records loaded
0 network records loaded
0 site loader records loaded
Fusion decoding enabled
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 and Phase 2 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
Mono audio decoding initiated; press Esc to exit...
Initiating FMPx link using link ID 20001...
FMPx link error = -5
[Server is not listening on selected link ID]
i don't see any input initialized like the old software like this audio input device #1 (Microphone (Realtek High Defini) initialized
i have my scanner with a discriminator taps output connected to a PC running widows 10 hooked up to my LG tv thru a hdmi port
i have used the free version DSDplus 1.051 version it works fine
This is my setting on my older version
when i click on it it comes up and on my screen it says this below and works fine
DSDPlus Rev 1.051
Appending synthesized audio to file 'DSDPlus.wav'
3 frequency records loaded
audio input device #1 = 'Microphone (Realtek High Defini'
P25 Phase 1 decoding enabled
I don't Know how to put in any commands or what setting I'm suppose to set them on
any help would be appreciated
Thanks!
  • DSD+ 2.347 settings.txt
  • DSDPlus 1.051 settings.txt
Kentuckyjoe
I figured it out thanks anyway
i would delete the first post but don't know how
slicerwizard
Toronto, Ontario
Read the docs:
Using DSD+ with external signal sources
DSD+ can be used with external signal sources such as a properly discriminator-tapped receiver
or SDR software such as SDR#. To use DSD+ with these sources, use the menus in DSD+ to
select Passive Digital Monitor mode and then to select the audio input device that carries
the digital audio signal. When running in this mode, DSD+ can be used to monitor conventional
analog and supported digital signals; DSD+ will not directly support trunk tracking.
Kentuckyjoe
Read the docs:
Thank!
