br0adband
First thing I noted: the signal is way way too "loud" on the spectrum, and since I have no idea what SDR device you're using all I can suggest is to back off the gain significantly.
Second thing I noticed: you're off frequency by the slightest amount but with a digital decode a few ppm can make all the difference in the world between a clear decode and all those ERR events you're seeing. Set SDR# so it's using the proper stepping size (6.25 kHz) and it shouldn't be an issue as long as you've got the ppm setting for the device correct as well. Might consider adjusting the Zoom as well to a further out view but that's a personal kind of preference so ignore it if you want.
Third thing I noticed: you're allowing DSD+ to be wide open meaning it's listening for anything that comes along - it works better by defining and limiting it to whatever specific format you want so, if you add -fr to your command line it'll listen for and decode only DMR/TRBO traffic which is more efficient operation.
I'm betting that if you adjust the stepping to 6.25 kHz it'll still be slightly off frequency because of a mis-adjusted ppm which can be handled fairly easily. You can use something like the ATSC signal at 470.310 MHz to lock in your ppm as accurately as possible.
Now, if you're using an SDR device of some kind that is using a TCXO the ppm setting shouldn't be an issue but even so it doesn't hurt to absolutely verify that device is accurate using that ATSC signal at 470.310 MHz (pretty much anywhere in the US you'll pull that in fairly strong except maybe Death Valley or whatever).
