DSD+: Can't Creat Windows
garys
Central Texas
One of the things about DSDPlus that I really like is that it has multiple priority levels. I can set a TG to be "HIGH" and it will pre empt a lower talk group. Or I can set it to "LOW" and it will be pre empted by a higher priority TG. OR I can use a number value that starts at 0 and goes to 99. The higher the number, the lower the priority.
I mention this because something like it would be a nice feature for scanners.
Probably PPM adjustment. Other adjustments were minor. Didn't switch from virtual cable, yet, since the audio was getting into DSD.
UPMan
In Memoriam
Arlington, TX
Correct. If using a single receiver, you are limited to whatever data is included on the Voice Channel during a transmission (i.e. system priority channel preemption only).
