DSD+ displays windows
Razorback55
Hello I'm new to using Dsd+ 2.395 fastlane.
Could you tell me how to display this window either with a command or in graphical mode?
and is there a command or a graphical mode to display the received hexadecimal frames such as the -Z command on DSD-FME which is as follows:
The current version, password protected and linked to your email, is 2.523, so you are way behind in the times. That said, when you open FMPxx bat file and/or 1-ROther (DSD EXE BAT file used to start the program) it opens the terminal.
Razorback55
Yes, I don't use the more recent versions because I'm afraid that the controls will change and that I won't know how to use it anymore. I use this version on a PC without internet and without updates. And I have a PC with the latest version but I don't use it.
In addition, I was wrong, it's not version 2.395 that I use on the PC without internet but version 2.465.
I find this software a little too complex for me.
For example, when I use the 1R.bat file (v 2.465), I have the terminal mode but the sound card is grayed out. And I don't know how to make it work.
And is there an equivalent of the dsd-fme -Z command to display raw frames?
Razorback55
I think I use the wrong terms so that we understand each other.
When I talk about the graphics mode, it's the window I put above (with the sound card) in which I select my choices with the mouse.
When I talk about commands it's this: DSDPlus -r1 -T -E -Pwav
I want to:
1-have the sound card not greyed out when I use the 1R.bat file
2-have the raw frames (the voice frames that are displayed in hexadecimal). How to do it?
Hexadecimal frames like this :
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
The answer is that you would go into the CTRL menu and select "Passive Digital Monitor". Then you could go back to INPUT menu and choose your microphone. Then you can use SDR Software and a virtual cable, or a mic input. But good luck with a mic input. And, it will NOT trunktrack unless you are using FMP*-CC.exe + 1R.bat.
And no, there is no way to say that perty information that DSD-FME shows, when using DSDPlus.
Razorback55
Thank you very much the sound entry works now.
Are the developers of DSD+ fastlane coming here? Is there a possibility that they will add the option of hex display of frames in the future?
mtindor
OH/WV DB Admin
I'm sure the developer reads the forum from time to time. Nobody knows what the developer is up to our planning, but I wouldn't count on the whole hex display of frames thing -- especially not in color. But ya never know.
