DSD Fastlane update files missing
erickirchey
Lebanon, MO
DSD Fastlane update 2.457 after completion I get 12 files passed 4 files failed 2 files not found.
I have downed base files update and extracted several times yet still getting this error any ideas?
dave3825
Suffolk County NY
Pretty sure one of the cmd windows will list the failed or missing files. Also, when you extracted the base files, did you read the included text document and place the files in the DSDPlus directory?
Back up all files prior
DSDPlus Fast Lane Base Files
This archive contains the following:
Executables folder:
FMP24.exe RTL SDR tuner/demodulator
FMPA.exe Airspy tuner/demodulator
FMPP.exe SDRPlay tuner/demodulator
FMP-Map.exe shows locations of tuned signals; relies on FMPx .csv license data files
LRRP.exe shows GPS location updates that have been decoded by DSD+
Survey.exe shows results of FMP24 spectrum survey
It is safe to copy all of these files to your DSD+ folder at any time.
DLLs folder:
lame_enc.dll used by DSD+ to create .mp3 audio recordings
rtlsdr.dll standard version of rtlsdr.dll; supports R828D tuners, supports bias tee control on V3 dongles
rtlsdr_FC0012.dll DLL known to properly support FC0012 tuners; to use, rename to rtlsdr.dll
airspy.dll Airspy interface
sdrplay_api.dll SDRPlay interface for 32 bit programs
libfftw3f-3.dll fast FFT library; used by FMP24, FMPA and FMPP
libusb-1.0.dll USB device support
msvcr100.dll used by other DLLs
msvcr90.dll used by other DLLs
msvcrt.dll used by other DLLs
pthreadVCE2.dll used by other DLLs
BatchFiles folder:
1R.bat run DSD+ in standalone mode for conventional and trunking systems
1Ra.bat run a second instance of DSD+ in standalone mode for conventional/trunking
CC.bat run DSD+ in control channel monitor mode
VC.bat run DSD+ in voice channel monitor mode
FMP24-CC.bat run FMP24; control first RTL SDR dongle
FMP24-VC.bat run FMP24; control second RTL SDR dongle
FMPA-CC.bat run FMPA; control first Airspy device
FMPA-VC.bat run FMPA; control second Airspy device
FMPP-CC.bat run FMPP; control first SDRPlay device
FMPP-VC.bat run FMPP; control second SDRPlay device
These files are provided as replacements for lost or damaged files
and as a reference for writing your own batch files.
Do not copy any of them to your DSD+ folder unless you have a good reason to do so.
ConfigurationFiles folder:
FMP24.cfg configuration file for FMP24.exe
FMPA.cfg configuration file for FMPA.exe
FMPP.cfg configuration file for FMPP.exe
LRRP.cfg configuration file for LRRP.exe
FMP-Map.cfg configuration file for FMP-Map.exe
Survey.cfg configuration file for Survey.exe
These files are provided as replacements for lost or damaged files.
Copying will destroy current configuration data!
DataFiles folder:
DSDPlus.networks DSD+ network data
DSDPlus.sites DSD+ site data
DSDPlus.frequencies DSD+ RF channel data
DSDPlus.groups DSD+ talkgroup data
DSDPlus.radios DSD+ radio/subscriber data
DSDPlus.P25data DSD+ P25 trunking systems data
DSDPlus.siteLoader DSD+ site loader feature data
FMP24.SurveyList spectrum survey control file for FMP24
FMP24.ScanList scan list file for FMP24
FMPA.ScanList scan list file for FMPA
FMPP.ScanList scan list file for FMPP
These files are provided as replacements for damaged or missing files.
Copying will destroy current data!
erickirchey
Lebanon, MO
I overlooked that before posting it’s working properly now thank you!
