DSD+FL freezing issue with new laptop on Windows 11 and RSP1A
jeremym70
Washington State
I have been running an older version of Fastlane with a older HP Win10 computer with an RSP1A for a couple years. Last week I updated to a new computer with Windows 11 and got the latest version of Fastlane setup. My problem is that after a short while when the screen goes dark and the computer locks FMPP-CC seem to freeze on me when the computer gets unlocked. Any decoding stops at the time and I can see the spectrum screen is frozen, the only way to get working is to close and restart FMPP-CC. I have gone through Device Manager and power save settings to try and turn off any sort of USB sleep mode, but nothing seems to make a difference. Any ideas? This is with the laptop plugged into a power supply. I am new to this laptop and Windows 11, but had everything working great on the old HP Windows 10 laptop with the same SDR as I am using now.
dave3825
Suffolk County NY
Since it does not appear to be usb related (at this time) you should be focusing on why the screen is going dark.
Go into power plan and either disable sleep for when plugged in. Or extend the time to suit your needs. You can leave the screen as is.
Please look at this post, maybe you can check and see if it helps.
Also check this setting..
jeremym70
Washington State
Thanks all for your replies, looks like disabling sleep mode when plugged in was the ultimate answer. I thought the USB's would stay alive even in sleep mode, but I guess that wasn't the case.
