DSD FL Missing files
Bethanylt241
Bethany WV
Hello, I am in the process of redownloading everything to a new computer since my old set up took a crap. I have redownloaded the public DSD file and DLLs. I then found the link DSD originally sent me after I paid and changed the last numbers 2p368 to 2p395 and downloaded and extracted to the public verson folder. I got everything in one folder but when I open up DSD Plus it says DSDPlus.P25data file not found in folder Same for siteloader and then says required data files not found in working folder. I can attest that they’re not in the folder and I am not sure why or how? I downloaded everything I thaught I needed to. I also notice FMP24 is not in the file either and that what I use. I am in need of some guidance here please? I have sent an email to DSD yesterday with no response.
cg
Connecticut
Since not every file was updated in every post, if DSDPlus folks dont send you stuff, you need to gather more old files. 2.383 (6/2/22?) probably would have the latest FMP24 file. FMPA and FMPP would likely be with 2.357 (10/20/21?) updates.
mcjones2013
Radio Communications Enthusiast
Sacramento, CA
There should be an option in the drop down menu to download the newest base files. Do that, then move all the individual files in each sub folder to the main DSDPlus folder.
Or email them and ask for a new ZIP file with all required files.
Bethanylt241
Bethany WV
I can’t open an event screen it won’t let me due to the missing files unless I’m missing something. I don’t have a 1r batch and if I open up CC batch it won’t open because of missing files.
PDXh0b0
Woodland, WA
And it’s quite frustrating that you have An issue and reach out with no response from DSD at all
I see what you are going thru...
Open a text editor, don't type anything in it, click file, save as "save as type, choose all"
File name DSDPlus.P25data
Click save
In editor , click File, new
Do the same that but name it
DSDPlus.siteLoaderView attachment 144270
Then you should be able to run dsdplus.exe and download the base files
Bethanylt241
Bethany WV
I found the issue, so when I downloaded the 2p395 zip file it only downloaded DSD file.exe and notes.exe. I now need the original download not the update. Is this something DSD is going to have to supply me or is there a way I can retrieve it. Unfortunately I have 2p368 in my email but it won’t open to download
PDXh0b0
Woodland, WA
See my previous post
I'll get it working if you want to teamviewer
