DSD+ FL with 2 Airspy Config
N7OLQ
Scanning since '77
Utah
I have DSD+ FL working fine with a single Airspy mini, but I'd like to add a second for full voice following. I've tried everything I can think of, but I can't find anything that tells how to add the second Airspy serial number. I assume it goes in the FMPA.cfg file with the other one, but everything I've tried is not recognized.
In my FMPA-VC.bat file it is FMPA -rv i2 -o20002 I've tried various -i values, but it says not defined.
Any help would be appreciated.
dave3825
Suffolk County NY
To add to, and unless something changed,
FMPA.txt said: Airspy device numbers are based on Airspy serial numbers;
lowest serial number = device #1, next highest serial number = #2, etc.
FMPAv2p7.txt said:
This version of FMPA supports Airspy and Airspy Mini devices.
Serial numbers for each of your Airspy and/or Airspy Mini devices should be
entered into your FMPA.cfg file. The ordering sets the device number for each device:
first serial number = device #1, second serial number = device #2, and so on.
Use -i<num> on the FMPA command line to select a specific device.
Reconrider
Inside the Galaxy
Radio Galaxy
I never added my airspy serial to the cfg file. I actually use 2 airspy devices and neither are programmed into the FMPA.cfg file.
N7OLQ
Scanning since '77
Utah
Like this, in FMPA.cfg :
B58069DC390E8333 26A464DC28444111 ; Airspy serial number list - mini
Thanks, that seems to have solved the error I was getting. What is the proper launch sequence? I've seen a few variations. FMPA-CC, FMPA-VC, 1R.bat then 1Ra.bat??
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
Two dongles:
Dual Dongles
FMPA-CC.bat
FMPA-VC.bat
CC.bat
VC.bat
Single Dongle
FMPA-CC.bat
1R.bat
N7OLQ
Scanning since '77
Utah
Two dongles:
Dual Dongles
FMPA-CC.bat
FMPA-VC.bat
CC.bat
VC.bat
Single Dongle
FMPA-CC.bat
1R.bat
I don't have a VC or CC bat. --- Never mind. I found them in the base files folder
mtindor
OH/WV DB Admin
They should be in the DSDPlusBaseFiles download available via the MISC --> Download newest base files
You unarchive those files to a separate directory within your DSDPlus folder, and then only copy the files over to the main DSDPlus folder that you need.
