DSD tune error -ds0
AJAT
Navajo County AZ
After I run DSD tune I get an error says "-ds0 invalid" after it completes the first "sweep". When I try to do a manual tuning some of the parameters are invalid. From the DSD text file these should work:
1: Rolloff filtering (-dr)
2: Hotspot size (-dh)
3: Scaling factor (-ds)
4: Damping level (-dd)
The only ones I can get to work are -ds -dd and -dv
Also when I run the manual fine tuning this does not happen:
"A decoding score will be displayed.
Pressing the up arrow will redisplay the previous command line,
which you can then edit and re-run."
In order for me to to see the score I have to intentionally put in an error so the error box comes up. If not the program just shuts down.
I an using the latest version of dsd Plus Fastlane. Any help on how to best fine tune raw .wav would be greatly appricated.
a417
are you using the dsdtune version that is recommended for fastlane?
