@Patrol1949 - One of your earlier posts suggested you want to run SDR# with DSDPlus Fastlane. I recommend that you DON'T DO THAT. Use the tools you just downloaded. Using Notepad, create a batch file in the same folder you saved your DSDPlus files. Add the next two lines to Notepad:
Start CMD /c dsdplus
Start CMD /c FMP24.exe -o20001 -f151.9850 -g14.4
I recommend you change the frequency from the example of 151.9850 to the DMR frequency you want to decode.
From the Notepad menu, Click
File
Click
Save As
A dialog box appears. In the File name box, type
runme.bat
Now click on the
Save as type dropdown
Change the Save as type from Text Documents (*.txt) to
All Files
Make sure you are in the folder where you saved the DSDPlus files. For me, this is C:\DSDPlus
Click the
Save button
If you haven't already done so, start a command prompt and navigate to the folder you saved the batch file. Example:
C:\users\username>
cd \dsdplus
Now you can start DSDPlus and FMP24 using the batch file you just created
C:\DSDPlus>
runme.bat
I just want to say good luck, we're all counting on you.
