DSDPlus 2.303
bravo14
Polk County FL
I have downloaded the new update seems very slow on p25 phase ll misses traffic or doesn't see it.
dlwtrunked
When I try to run it after upgrading from 2.186, I now get "Not a valid Win32 application".
BM82557
Berkeley Co WV
Additional from Notes.txt --
FMP24 2.71
Added CPU loading option to reduce I/Q stream dropouts:
Run FMP24 on an idle PC (close all other programs).
Press L to start I/Q dropout test.
If FMP24 reports a high error rate, i.e. more than few dropouts per minute,
press L to stop the test, then press E to toggle CPU loading, then press L to start a new test.
If extra loading causes I/Q dropouts to cease or be greatly reduced,
you should always enable CPU loading when using FMP24.
Reduce CPU clock rate to limit battery drain / heating when enabling CPU loading.
If multiple copies of FMP24 are in use, only one copy should need CPU loading;
choose a copy that is always demodulating signals, i.e. a 1R or CC copy.
Use -e on FMP24 command line to enable CPU loading or press E to toggle on/off.
FMP24 uses modified spectrum display colors when CPU loading is enabled.
FMPP 1.18
Restored SRP1a LNA gain range (untested)
dlwtrunked
You probably didn't unzip it properly.
I downloaded again and this time things seem fine up to that point. I was updating from earlier and went back to start due to missing files as it was sort of a whack-a-mole problem. But after putting everything together now I am stuck with a message about the server not listening. (The earlier version is still working fine in another folder. That Fastlane version was "pre-server" versions and simple to run.)
So now I am trying to use FMPA as I cannot get the old .bat to just run the current SDPlus. version. I have FMPAs successfully just tuning the AirSpy. But it is unclear still to me that I know correctly which of the programs I need to start in what order with what parameters in batch files after that. I have read everything I can find but seem to be not finding a good reference on how to set things up so they work. I have tried various variations on .bat files. The latest try results in a server is not listening message. Is there a good sample of which programs to start in what order with contents of the .bat file???
slicerwizard
Toronto, Ontario
The original, unmodified FMPA-CC.bat and 1R.bat files should be all that you need to run. They're in the base files download. It doesn't seem to matter what order they're started.
dlwtrunked
Note that I did another re-install starting with the the free and ending with the current. It is still not working. I had to add the current airspy.dll and an empty DSDPlus.P25data as there was none and I wonder why. Additionally, there is no 1R.bat in any of the unzipped downloads that I downloaded (including the the base files). As mentioned, I was running Version 1776 and it was working fine but I am trying to get the current version to run.
dlwtrunked
Here are the batch files I am running:
FMPA -i1 -o20001 -f851.6125
DSDPlus -rc -i20001 (I assume the mentioned 1R.bat is an equivalent of this.)
Error message is:
FMPx link error =-5
[Server is not listening on selected link ID]
The appears after the DSDPlus .bat file is run.
BM82557
Berkeley Co WV
You were running DSDPlus with SDR# version 1776? I am understanding you correctly?
dlwtrunked
Oops, sorry about that. DSDPlus version was 2.186 (sometimes with SDR# and sometimes with HDSDR both with VBCable). But I need to do some things that are only in newest versions.
dlwtrunked
I have tried a different PC running Win 8--still same error message. I assume something is wrong with my .bat parameters, I need to run something else, or am missing another file.
dlwtrunked
I think I have found the problem so hold off on trying to help me. I think I installed the wrong base files.
dlwtrunked
Indeed, that was the problem--I was using an older basefile by mistake and it was not compatible.
CanesFan95
Was Homeboys-Scanna
Banned
FL
Does this "I/Q" drop-out thing mean DSD+ will actually decode audio stable that we can actually listen to? Dosen't matter what you do with the settings or how good the signal is. DSD+ just doesn't decode digital voice reliably at all.
polkaroo
Missed him again!
Anyone know what issue the CPU loading feature on FMP24 is supposed to solve? I mean, is it supposed to ham-fistedly 'reserve' CPU cycles for itself so as to not have dropped bits?
GTR8000
NY/NJ Database Guy
BEE00
Kazzaw
South East QLD, Australia
Is anyone else seeing FMP Crashes?
Error
FMP24 2.71 -i1 -o20001
Unrecoverable error encountered:
Exception number = 0xC0000005 (Access Violation)
Instruction address = 0x41DF81
Action: Read of address 0x3BD1000 (62722048)
Register dump:
DS: 0000002B CS: 00000023 IP: 0041DF81 EAX: 00012C00
ES: 0000002B SS: 0000002B SP: 0420FF18 EBX: 00012811
FS: 00000053 Fl: 00010206 EBP: 0420FF24 ECX: 03BD1000
GS: 0000002B ESI: 03BD1000 EDI: 03151FB8 EDX: 0012B000
[Press Ctrl-C to copy this text to the clipboard]
OK
