DSDPlus audio source problems
icissel
Boston, MA
I am using DSDPlus Fastlane which has been working great until today I tried to get decode from SDR# using virtual audio by running dsdplus to figure out my in/output:
Code:
\Users\ianci\OneDrive\Desktop\DSD>dsdplus
DSD+ 2.360
Current working directory is "C:\Users\ianci\OneDrive\Desktop\DSD"
DSDPlus -h for help summary
Appending synthesized audio to file '1R-DSDPlus.wav'
Assuming FMPA/FMPP/FMP24 is signal source; auto polarity detect is disabled
audio output device #1 = 'Speakers (Realtek High Definiti'
audio output device #2 = 'CABLE Input (VB-Audio Virtual C'
audio output device #1 (Speakers (Realtek High Definiti) initialized
Usually VB Cable is listed as output so I am assuming something is messed up in one of the config files but not sure which. Any help would be appreciated.
icissel
Boston, MA
Appears to be output #2 in the log you provided?
thanks for the reply! usually that will say input but even when i select vbcable and run:
Code:
 dsdplus -rp -i2 -o1
My result is:
Code:
DSD+ 2.360
Program role is passive digital decoder
Appending synthesized audio to file 'DSDPlus.wav'
audio input device #1 = 'CABLE Output (VB-Audio Virtual '
audio input device #2 = 'Microphone Array (Realtek High '
audio input device #2 (Microphone Array (Realtek High ) initialized
P25 data loaded; 1 network, 4 sites, 41 channels
22 frequency records loaded
2291 radio records loaded
427 group records loaded
6 site records loaded
0 network records loaded
0 site loader records loaded
Fusion decoding enabled
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 and Phase 2 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
with no decoded audio. When I run FMP24 and 1R I have no problems.
slicerwizard
Toronto, Ontario
Notes.txt strikes again:
Using DSD+ with external signal sources
DSD+ can be used with external signal sources such as a properly discriminator-tapped receiver
or SDR software such as SDR#. To use DSD+ with these sources, use the menus in DSD+ to
select Passive Digital Monitor mode and then to select the audio input device that carries
the digital audio signal.
When running in this mode, DSD+ can be used to monitor conventional
analog and supported digital signals; DSD+ will not directly support trunk tracking.
icissel
Boston, MA
it was already in passive digital mon mode, the "-rp" flag in my post. your comment was helpful though I didnt realize the input could be selected via the gui so thanks!
