DSDPlus batch files.
Bear15
does this sets of batch files seems ok?
I am experiencing terrible audio.
**sorry for the long post posting all X4 .batch file logs**
1.bat:
D:\FastLane>FMP24.exe -i1 -o20002 -b12.5 -f867.4625 -rc
FMP24 2.65
Current working directory is "D:\FastLane"
SDR sampling rate = 2.400 MHz
Spectrum window width: 1024
FFT size: 32,768
Spectrum update rate: 10 Hz
Step size table: 5.000 6.250 7.500 12.500 15.000 25.000 100.000
DSD+ path is "D:\FastLane"
Primary frequency list: '.\FreqList.csv'
Secondary frequency list: '.\FreqList2.csv'
Database search distance: 99.90 miles
Base latitude/longitude: 19.7163 -155.6241
Using RTL SDR device #1
Using TCP port #20002
12.50 kHz RF bandpass filter selected
Initial frequency set to 867.462500 MHz
Role is control/rest channel monitor;
Auto-starting control/rest channel following mode
Optimizing FFT calculations... done.
SDR device count = 2
SDR device #1 serial string = '00000001'
SDR device #2 serial string = '00000001'
Found Rafael Micro R820T tuner
Tuner type=5 (R820T)
Serial string = '00000001'
Sampling rate set to 2.400000 MHz
Frequency correction factor = 0.0 PPM
No frequency data files found
Listening on TCP port 20002
Trunk control/rest channel following active
Accepted local connection on port 54163
2.bat
D:\FastLane>DSDPlus -rc -i2 -i20002 -v3 -wsl400.2 -wss100.200 -wel0.1 -wcl0.445 -wes400.520 1>>CC.log
DSD+ 2.246
Program role is control/rest channel decoder and voice channel controller
Source audio waveform window origin set to (400,2)
Source audio waveform window dimensions set to 100x200
Event log window origin set to (0,1)
Channel window origin set to (0,445)
Event log window dimensions set to 400x520
Appending synthesized audio to file 'CC-DSDPlus.wav'
Assuming FMPA/FMPP/FMP24 is signal source; auto polarity detect is disabled
audio output device #1 = 'Speakers (High Definition Audio'
audio output device #2 = 'MG248 (2- NVIDIA High Definitio'
audio output device #1 (Speakers (High Definition Audio) initialized
P25 data loaded; 1 network, 2 sites, 11 channels
0 frequency records loaded
1676 radio records loaded
190 group records loaded
0 site records loaded
0 network records loaded
22 site loader records loaded
Fusion decoding enabled
D-STAR decoding enabled
NXDN4800 decoding enabled
NXDN9600 decoding enabled
dPMR decoding enabled
DMR/MotoTRBO decoding enabled
P25 Phase 1 and Phase 2 decoding enabled
X2-TDMA decoding enabled
ProVoice decoding enabled
Mono audio decoding initiated; press Esc to exit...
Initiating TCP connection to 127.0.0.1:20002...
Connected to 127.0.0.1:20002
TCP link established
3.bat
D:\FastLane>FMP24.exe -i2 -o20001 -b12.5 -rv
FMP24 2.65
FFT size: 32,768
Using RTL SDR device #2
Using TCP port #20001
Role is voice channel monitor;
Auto-starting voice following mode
SDR device #1 is in use
Listening on TCP port 20001
Trunk voice following active
4.bat
D:\FastLane>DSDPlus.exe -rv -i20001 -o1 -v1 -wsl400.2 -wss100.200 -wel0.1 -wcl0.445 -wes400.520
DSD+ 2.246
Program role is voice channel decoder; audio modes set to mono
Appending synthesized audio to file 'VC-DSDPlus.wav'
1690 radio records loaded
191 group records loaded
Initiating TCP connection to 127.0.0.1:20001...
Connected to 127.0.0.1:20001
In your opinion what can be tweaked for P25II as the same setup work flawlessly in SdrTruning.
I have an audio sample but unable to upload it.
