DSDPlus DSDPlus Fastlane V2.228 trunking setup issue
goldenears7
So with this new update my trunking no longer works. Originally I used the CC batch file so that I can use any SDR software and move to any trunking channel as I please instead of putting a frequency into FMP24-CC. I cut out using FMP24-CC all together as it was not needed. I would then open up FMP24-VC and then the VC batch files. My FMP24-VC would use the TCP linking to send to the VC batch file.
For the new upgrade I know I can change settings in the event log now under input to Cable output (VB-Audio-virtual) and it decodes in my main CC window. But i'm having problems trying to get it to send to FMP24-VC and VC now. My file setup is listed below. I appreciate any help.
CC batch file
DSDPlus -rc -i3 -v3 -wsl400.2 -wss100.200 -wel0.1 -wcl0.445 -wes400.520 >>CC.log
FMP24-VC batch file
FMP24 -rv -i3 -o20002 -P0.0
VC batch file
DSDPlus -rv -Pwav -i20002 -v3 -wsl400.210 -wss100.200 -wel172.522 -wcl528.0 >>VC.log
goldenears7
Upgrade to DSD+ v2.235 and see how you go. DSD+ v2.228 has a few bugs that caused problems.
Thanks! I think it was combination between upgrading to v2.235 and my SDR# software. The SDR# software I was using had all the extra plugins added. I uninstalled and installed the regular one and seems to be working fine now.
