DSDPlus DSDPlus Setup
NewbGuy
Kentucky
Might have bit off a little more than I can chew with this one.
End goal: see if I am close enough to monitor Kentucky State Police
Currently: Running 2 RTLs on SDRTrunk, works perfectly.
So, I've taken my stream down trying to play with DSDPlus today, free version since FastLane is full now.
So I've downloaded the KY.csv and placed them in my DSD fold and changed FMP24.cfg to reference those, so running FMP24 I hear noise and it scans the freq in my radius I put in.
Now for the Conv P25, I've added the following to DSDPlus.freq... file,
P25, 123, 1, 9, 460.3125, 460.3125, 0
P25, 123, 1, 9, 460.2875, 460.2875, 0
P25, 123, 1, 9, 460.4375, 460.4375, 0
P25, 123, 1, 9, 460.225, 460.225, 0
P25, 123, 1, 9, 453.500, 453.500, 0
BUT 1. FMP24 doesn't seem to scan them, I get conformation in DSD that 6 freq are loaded.
2. My TCP link is giving a connect error 10061 (No connection could be made because target machine refused)
I'm remoted into the same machine so the target machine is the same machine the program is running on.
I've made exceptions to my firewall and disabled it completely with no change.
I'm sure it's very much user error on my part.
You kind of lost me @NewbGuy if using FMP24.cfg you don't need your KY.csv, all you do is add the control channel freq in the FMP24.cfg, or any freq and change to the cc once you start it. Once it locks onto the cc it will automatically scan through the voice channels.
NewbGuy
Kentucky
It's possible I don't need FMP24 might be using the wrong one for my system? There are no CC it's a P25 Conv (multicast?) system I believe, where each tower transmits out on a different freq.
Coming from SDRTrunk, this is a big change and I've read till my eyes are crossed and have made a little progress but not to my end result yet.
You need a frequency to start FMP24, but it sounds like what you need is a scan list, which is different from FMP24.cfg, look for FMP24.Scanlist and after DSD+ starts press S.
NewbGuy
Kentucky
I had already started down that road after I posted this so, now I'm hearing some static (not sure if its calls or not) but DSD+ isn't linking to FMP24 which was my second issue.
FMP24 Scan List.pngScreenshot 2025-12-19 172559.pngScreenshot 2025-12-19 172657.png
RMason
Mississippi / Colorado
How are you starting FMP24 and DSDPlus? Are you using:
FMP24-CC.BAT​
and​
1R.BAT​
Or are you doing something different?
NewbGuy
Kentucky
FMP24-CC.BAT​
and​
1R.BAT​
Was using FMP24 then DSDPlus, just tried using the FMP24-CC and got RTL Device #1 in use and clicked ok and it closed the program.
saioke
What do your 1R.bat and FMP24.CC.bat look like?
Also make sure you aren't trying to run it with other SDR programs running. Restart your PC if you have to.
dave3825
Suffolk County NY
DSDPlus does not utilize the dsdplus.freqs file for p25. Its handled automatically by a different file after tuning to an active control channel on a P25 system.
DSD+ v2.5
no P25 frequency data is required in the DSDPlus.frequencies file,
but you may manually add frequency data for your own reference
(DSD+ will ignore any P25 frequency entries that you add)
Your state is building out a P25 system at the moment.
As stated for conventional freqs, you would populate the fmp24.scanlist. Not sure the formatting you went with will work or not.
You have Freq, Modulation, Name
FMP24.scanlist states
Freq, Modulation, Bandwidth, Delay, Name
453.600 P25 BW=12.5 DELAY=5 Name.
; Sample scan list:
118.3 AM BW=12.5 DELAY=2.5 Miami Tower
145.17 DMR DELAY=1.5 N2GKG
162.4 FM WX
454.35 NX48 Acme Inc.
163.8125 P25 BW=12.5 DELAY=5 Feds
<EOF>
; any entries after <EOF> line are not scanned
For your connection error, post the contents of the 2 files @saioke mentions above.
NewbGuy
Kentucky
There is usually radio communication with Monroe and Lawrence County, but it’s typically from EMS or the police department. You might also find information about local businesses on frequencies like 467.850 and 467.975, and sometimes at the big stores. But sadly they took away they took away the radio coverage from their main fire dispatch.
154.235KWN469RM114.8 PLLwrnce Fire/EMSFire/EMS: Dispatch (Simulcast Countywide)FMNFire Dispat
I’ll get that updated, I just assumed it used defaults if nothing was there.
NewbGuy
Kentucky
Let me try this again. Sorry, currently in the deer stand.
Edit: just noticed I posted FMPA but FMP24 looks the same
NewbGuy
Kentucky
So maybe I worked through it.
Updated FMP24.scanlist
And I noticed when starting FMP24.bat it showed 3 dongles, even though I only have 2. So I changed from -i1 to -i2 and was able to get past the error.
Is there a way or reason to use 2 dongles since it’s not a trunking system?
dave3825
Suffolk County NY
Any way you can take the screen shots from that pc instead of remoting in, or make them full screen?
In the fmp24 bat, set to i0 and it will grab first available dongle.
Also, if you’re just going to be scanning a list of conventional freqs, you would use just one dongle.
NewbGuy
Kentucky
I can when i get home. I currently think I’ve got it working.
Just curious what imput and outputs need to be on DSDPlus. Notes say for digital you need TCP link so i think i might have issues with mine there.
dave3825
Suffolk County NY
If your going to do any play back thru Trunking Recorder or Rdio Scanner,
Th FMP24-CC.bat and 1R.bat should look like this.
I use i0 to select the first available dongle. You can change the 935.0 freq to anything you want but pointless if your going to use Fmp24.scanlist. Once your Fmp24 and DSD are linked, click title bar in fmp24 to focus, then press s to start scanning the list. To stop scanning, hit esc one time.
cg
Connecticut
You can put conventional P25 channels in the frequencies file if you intend to create aliases for the radios seen. The frequencies would serve as the key to match a pseudo Net ID to a list of aliases.
chris
gary123
here is a .bat that starts FMP24 then starts dsdplus all in one.
start FMP24 -o7777 -f866.9750 -b12.5 -g44.3
timeout /t 6
call dsdplus -i7777 -v3 -O NUL
Change the 866.975 to your proper control frequency.
I have not tried setting up a TG scan list so when you get yours going I would appreciate some tips on the successful process.
NewbGuy
Kentucky
timeout /t 6
I was able to use i2 or i0 either and get it to run successfully. I’m unable to do much testing since I’m in a valley and I don’t believe I can reach either tower close to me.
