DSDPlus to SDRUno help! PLEASE!
Patriot2120
SARASOTA
I am trying to run DSDPlus and use it with SDRUno and an RSP1A. The problem I am having it that I cannot change the INPUT source to DSDPlus. When I open the FMP-24 EXE and the screen opens, it shows my OUTPUT as Realtek Speakers, but does not show an INPUT source! What am I doing wrong? I have watched several videos on how to change it and nothing works. Any help would be greatly appreciated or if someone can do a TeamViewer into my computer to take a look, please let me know.
Bill
thewraith2008
FMP24.exe can only be used with a RTL dongle, not a RSP1A.
You didn't state what version of DSD+ you are using.
If you have the fastlane version of DSD+, then use the FMPP.exe with the appropriate command line options.
If you don't have the DSD+ fastlane version, then you will need to setup SDRUNO so the audio output is via a virtual cable with absolutely no DSP applied to that output audio which then you configure DSD+ to that virtual cable to decode from.
slicerwizard
Toronto, Ontario
You're not making sense. You use SDRUno or FMPP to access the RSP1A. Which one do you want to use?
Patriot2120
SARASOTA
When I use FMPP.EXE SDRUNo will not open. If I close DSDPlus with Fastlane, SDRUno will open. When you say "appropriate command line options" what are you referring too?
slicerwizard
Toronto, Ontario
Then follow the instructions in the Notes.txt file:
Using DSD+ with external signal sources
DSD+ can be used with external signal sources such as a properly discriminator-tapped receiver
or SDR software such as SDR#. To use DSD+ with these sources, use the menus in DSD+ to
select Passive Digital Monitor mode and then to select the audio input device that carries
the digital audio signal. When running in this mode, DSD+ can be used to monitor conventional
analog and supported digital signals; DSD+ will not directly support trunk tracking.
So just start DSD+ directly by double clicking on the DSDPlus.exe file in Window Explorer and then follow the instructions above to get DSD+ listening to the virtual audio cable.
SDRUno ---> virtual cable ---> DSD+
