DV1
john56
Toledo, Ohio
Just received my AOR DV1 today and got it running. My only question is...how do you correct a mistake
when entering the text for a channel? If I take it out of memory mode, it will find the next channel, and I do not want that. I want to correct the text that is in memory mode.....
Thanks,
John KD8BIN
F5HPE
France
Sorry, I don't understand your trouble. Can you explain how your perform your issue?
john56
Toledo, Ohio
Thanks for the reply......I just deleted the channel and reprogrammed it with the correct text. I should have
done that initially....
The issue was how to correct the text on a channel you programmed into memory when you make a
mistake on the channel name
John KD8BIN
F5HPE
France
Hum! Good question!
Franckly I can't tell you how to do as I work with DV1 Manager and my software do it for me....
Sorry for not being helpful.
