DVRS compatibility issue
issy80
Hello all. I made a mistake and am trying to figure out how to fix it. I was trying to drag and drop frequencies from a 8000 code plug to an 8500. I've messed something up with the DVRS system and can find where to fix it. I've tried to read the radio and write the same plug back. I can read it fine, I keep getting the same response on write. This is the error I receive when trying to upload a code plug.
"Compatibility error. The DVRS Range Extension feature is not compatible between source and target. Operation not permitted."
I have even tried to write a plug from a previous session to no avail. The radio is flashed for DVRS, so at this point, I'm lost. Does anyone have a pointer here, I'd sure appreciate it. Thank you.
