DXing TPMS sensors with RTL_SDR
jwt873
Woodlands, Manitoba
I recently picked up a wireless doorbell. Right off the bat it was getting triggered by nearby 433 MHz signals.
Looking at the waterfall from my NooElec R820T I noticed that it was really busy around 433.920. I was wondering what these signals were.
So I installed the RTL_433 device decoding program on my Linux computer and plugged in the NooElec R820T SDR dongle. I connected it to my 21 element 432 MHz Yagi pointed at the road 200 feet from my house.
Darned if I'm not picking up tire TPMS sensors from a lot of the passing cars. Along with that I'm getting someones weather station.
I understand the RTL_433 program is also available for Windows and as a plug-in for SDR#
I've never DXed TPMS sensors before. :) :)
devicelab
Radio N.E.R.D
WA (USA)
and just imagine what you could hear from the NSA's TPMS sensors designed by the TAO engineers!
Spleen
Baltimore, MD
I remember when I first joined RR and there was discussion about monitoring drive-thru on 49?mhz.
I thought - what could be less interesting than drive-thru comms.
Now I know. :):)
Admittedly, I was somewhat addicted to firing up the scanner on 49MHz when some of the apartment buildings still used that range for the doorbell/intercoms. Friday or Saturday night, when the bars started closing...in an urban environment...good times...those convos beat drive through and (most) cordless phone conversations hands down... ;)
Jphila20
Retired LE. Honor our Fallen.
Southern Lorain County, Ohio
I'm a little familiar with Unbuntu, novice to be more like it, and have used OP25.
Will the RTL_433 device decoding program work in Unbuntu and is it a stand alone software?
I looked on Github and I don't see a windows version. I mostly use Unitrunker and SDRTrunk.
Thanks!
John
R0am3r
Salt Water Conch
Oneida County, NY
Anyone with a few skills can build the Windows executable by cloning the rtl_433 github repository with Visual Studio. The build instructions are included in the BUILDING.md file. I believe you will need PothosSDR installed. During the PothosSDR installation, choose "Add PothosSDR to the system PATH". The git clone repository is located here:
jwt873
Woodlands, Manitoba
I'm using Neon, which is based on Ubuntu. rtl_433 is a stand-alone program that you run from a terminal.
If you've set up a repository for software updates etc, you can install the program by opening a terminal and typing:
sudo apt-get install rtl-433
Your system should fetch it from the repository and then install it. After that, type: rtl_433. If it recognizes your SDR receiver, it should run.
One thing to note.. To install it, you use rtl-433 (with a dash). To run it you use rtl_433 (with an underscore). Not sure why they did that.
Jphila20
Thanks for info!!
merlin
DN32su
I installed and played with this a bit on Windows. Running the test, my dongle passed, so now to look for something to log.
Not much here, once in a pink moon, maybe a key fob.
Cool program.
merlin
DN32su
Now I know. :):)
Baby monitors - Smooz
dlwtrunked
they4kman
St Petersburg, FL
It's amazing to me how well rtl-433 and rtlamr work. For about a year and a half, I had rtlamr feeding my meter readings to my personal website, where I'd integrate it with residential rates automatically extracted from the most frustrating of APIs: PDF files. Being able to view second-by-second (well, the meter really only yelled into the ether every 15s, IIRC) power bill amounts was a guilty pleasure... until the power company switched out the RF for the new, fancy Zigbee meters =/
HamImports
A while back, I wrote a small NodeJS program to consume output from rtl_433 and generate some stats about local devices. rtl_433 will spit out stats to a syslog server, so my program acts as one of those to receive the data. It's far from polished, but I could post it to GitHub if anyone is interested.
