Dyer County Scanner Question
dewtlw
Dyersburg,Tn
Have a Uniden BC345CRS scanner. Used to pick up fine for county sheriff now when it stops on channel there is no sound. Tried squelch etc..Help..Dyer co tn..any help would be appreciated..Would love any codes that may work..fire, ems, ambulance , police, air evac etc...Thanks
wtp
Port Charlotte FL
i have a couple of unidens that do that.
the usual fix is to plug in a jack that fits (3.5MM) a couple of times until you hear something.
trip the squelch to hear the noise first would help.
another thing is that if computer speakers are handy try them.
RIVER_5
ÆS LØVER
TN - Dyer County (45) - Public Safety Talkgroups
DEC HEX Mode Alpha TagDescriptionTag
48100 bbe4 TDYER STATEWIDEStatewide Access Interop
48133 bc05 TDCF-DISPCounty Fire - Dispatch Fire Dispatch
48130 bc02 TDCSO-DISPCounty Sheriff - Dispatch Law Dispatch
48112 bbf0 TDYERSBURG EMSDyersburg EMS Dispatch EMS Dispatch
48101 bbe5 TEDYERSBURG PD 1Dyersburg Police - Dispatch 1 Law Dispatch
40001 9c41 TDYERSBURG PD 2Dyersburg Police - Dispatch 2 Law Dispatch
48132 bc04 TNEWBERN FIRENewbern Fire Department Link Fire Dispatch
48131 bc03 TNPD-DISPNewbern Police - Dispatch Law Dispatch
ka4bni
Dresden, TN
At one time Dyer County SD was multicasting their DMR traffic on their old analog channel 460.100 mhz. Not sure if they're still doing this. About the only thing left, that you can pick up in Dyer County with that BC345 is Dyer Co FD on 150.775, and the Rescue Squad on 453.075. For everything else, you'll need a scanner capable of Phase II P-25 trunked. Most of the county channels are hard patched over to a P-25 talk group and most everything is clear except Dyersburg PD and FD.
INDY72
Indianapolis, IN
DPD 2... Is it still clear or now E too?
INDY72
Indianapolis, IN
Dyersburg PD 2 does not exists that was the old TG before TACN TG's
Then what is that TACN DPD 2 TG used for now? Is it even in use? If not, then someone sub it as DOA so the DB can be halfway accurate again.
400019c41TDYERSBURG PD 2Dyersburg Police - Dispatch 2
INDY72
Indianapolis, IN
That was the TG for the old Dyersburg P25 system that became TACN and they were given new TG's and abandoned the old TG.
Hopefully whoever is the TN admin now can get rid of that so no confusion for those that just download the DB and don't actually read the forums. Also side note: Those TACN trucks are cute. :)
