Eastern PA Freqs?
TechTwo
Pottstown, Pennsylvannia
Hi All,
I was wondering what are good aircraft frequencies for eastern PA, I live about 30 miles west of Philadelphia.
I usually listen to railroads and Montco Police/Fire/EMS but thought I might like hearing airplanes as well.
Any help will be appreciated.
Michael
Colin9690
Delaware County, OH
Lewis Center, OH
Look for freqs in the database for Washington Center, which is the routing facility in your area. You will hear the planes very clearly because they are at high altitudes, but chances are you won't be able to hear the air traffic controller.
jojoburke
I too am in your general area (eastern PA). Try www.airnav.com and click on airports. Browse by state. You will find airports like N99 (Brandywine apt in W.Chester, PA) and KPHL for Philly. Listed in these airport directories are the active frequencies. Remember that aircraft freq's are AM, not FM mode. KCChiefs9690 is also correct that the conversations will be mostly one way. You will here the aircraft but not the controllers. One exception to try in our area is the NY center on 135.450. You can hear both controller and aircraft.
Dank
MD
Two more places to look for info and freqs are the MilAir thread on the Maryland forum http://www.radioreference.com/forums/showthread.php?p=241645#post241645 because alot of the planes from MD, A-10 specifically make routine trips up to the ranges in PA. You will also hear tankers for refueling. The other place to look is the Wiki page for MilAir. It will give you a glossary of terms you may not know as well as freqs and links to other freq sources.
Dan
EricCottrell
Boston, Ma
Hello,
Also by reading the MD MilAir thread you will see there is Milair activity from Willow Grove, which is located north of Philly.
http://www.airnav.com/airport/KNXX
I did some brief listening to New York Center and Philly Approach frequencies while down in Kulpsville. Very Busy.
73 Eric
PHL_Approach
Kulpsville, ehh. I live in Lansdale, small world.
These are the area ZNY freqs and all the PHL App/Dep freqs.
ZNY ARD55 - 134.60 - Mainly New York departures, but the transmitter is north of Philly about 30 miles along with the PTW92 and PARKE39. I pick them up.
ZNY PARKE39 - 132.10 - Potomac Arrivals and New York Departures.
ZNY MXE25 - 135.45 - Philly Departures out the MXE, STOEN and PENSY exits (That is where you are)
ZNY DIXIE68 - 118.97 - Philly Departures out the DITCH exit.
ZNY PTW92 - 124.62 - Philly Departures out the PTW exit.
Philly TRACON
Final Vectors One - 125.4 - Runs the 27R/26 final, when SAPR2 is in effect FV1 will run only the 26 final. (SAPR2 - Simultaneous Approaches to Parallel Runways - 27L/26 is used by arrivals while 27R and 35 at intersection Kilo is for departures)
Final Vectors Two - 132.67 - Runs the 35 final and the 27L final when the SAPR2 is in effect.
North Arrival 128.4 - Feeds arrivals from BUNTS 1 /BOJID 1 and SLATT1/SPUDS1 Arrivals in the north to Final Vectors.
South Arrival 126.6 - Feeds arrivals from the Cedar Lake 8 and DPNT 4 Arrivals to Final Vectors.
North Departure 124.35 - Departures out the MXE, PTW, STOEN, and PENSY exit gates
South Departures 119.75 - Departures out the DITCH, OOD, and TEBEE exit gates
Yardley Satellite 123.8 - Provides service for mainly TTN and PNE
Pottstown Satellite 126.85 - Provides service to LOM, and PTW
Dupont Satellite 118.35 - Rarely open
Woodstown Satellite 127.35 - Provides service to ILG
South High 125.12 - A high level departure, rarely open
North High 126.07 - A high level departure also doubles as arrival sector for TEB aircraft on the JAIKE1 Arrival transitioning from ZDC shelves to N90. Open on busy evenings and when staffing levels enable it.
I hate opening old threads, but figured someone might find the info useful.
radioscan
Radio Sensei
Southern Ohio
Yes, Eric, myself and about 150 others were just at the Winter SWL Fest.
You are welcome to join us for the 20th Anniversary fest next year and you don't
have far to travel like we do. ;)
http://www.swlfest.com
