EDACS LCN zero question / Help
scan-pa
RRDB Admin
Lebanon, Pa.
Anyone know what a LCN-0 in the Ch. order would mean?
System is a Digital EDACS standard W/ Analog & Digital ProVoice Audio Modes.
bassmkenk2508
MS Gulf Coast
where did you hear of this LCN-0?
what did they talk about regarding "LCN-0"?
so far my best guess is the very first one in the channel order (0,1,...) or the last one of ten channels (1,2,...,9,0).
scan-pa
RRDB Admin
Lebanon, Pa.
Etrunker!
Lebanon County South System
MAP=00000000
OPTIONS=NVDF
PLAN=0
DESCR=E-GE
THRESHOLD=50
DISPOSITION=abdbebfulznbpbsn
v0x000 ,0,ffff,d1
dv453.1625,1,ffff,6e05
dv453.3125,2,ffff,7328
dv453.4500,3,ffff,24fb
dv453.5875,4,ffff,25c1
v453.7625,5,ffff,1714
dv460.3625,6,ffff,3a6b
dv460.5000,7,ffff,2d76
greenthumb
Colorado DB Administrator
As I recall, LCN 0 is the busy queue in EDACS trunking. So if a radio has been assigned LCN 0, it is in the busy queue. There is a string of information that you can add to your trunker "XXXXXsys.txt" files that will show the busy queue and a few other features - i'll see if I can dig it up and post it.
greenthumb
Here it is....replace the text in your XXXXXsys.txt with this:
MAP=00000000
OPTIONS=NVDF
PLAN=0
DESCR=E-GE
THRESHOLD=50
s DOWNLINK,1a,ffff,0
s RESERVED,1b,ffff,0
s CONVERTc,1c,ffff,0
s QUEUEDid,1d,ffff,0
s SYS-BUSY,1e,ffff,0
s DENIEDid,1f,ffff,0
...and you will see the different radios assigned to those different LCNs as they use those features. An explanation of those features can be found at:
http://www.radioreference.com/wiki/index.php/EDACS
