southhaysfireman
- Joined
- Oct 11, 2005
- Messages
- 74
- Reaction score
- 0
I am trunking and ocationaly I will miss a part of the conversation. My scanner is trunking properly could I be missing a frequency?
GTO_04 said:It is possible. Also make sure you have the correct LCN order. The channels must be entered in a specific order and start in the correct location in the scanner bank.
GTO_04
Yes and on some scanners you need to start programming at channel 001 instead of channel 000. On Motorola systems you can program out of order but EDACS requires you keep the order.
williams63 said:Yes the frq's must be in order...lowest to highest ,a nd starting at channel ( on scanner ) 01 or 001.
k0bzv said:During a transmission, press and hold the TRUNK key until ID HOLD appears. Hit it again to unlock
the talk group.
Knifeguy said:Nice.
With Trunks (not sure if its just Motorola Type II 800's or Edacs too), whenever I hit the Hold button on my Pro-97, and also with my BC796? (I'm not sure), I get a loud hum. I can't stop on a trunk.
I haven't really tested it yet on my BC246 & 396, but I don't think that happens on those two. I didn't think you'd want to stop anyway, cause you wouldn't follow the call, but It occassionally changes channels, and I miss a piece too. For me, I just assumed the reception is poor in those cases, and the unit moves back to scan mode.
